Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Defer Update When Changing BOM Structure
3 REPLIES 3
338 Views, 3 Replies
Hi everyone,
I have a script for one of my assemblies that changes the BOM Structure on supressed items so that my drawing BOMs show correct quanties for the current representation. The assembly I use this on is very large so the script takes a long time to run. To change the BOM structure I have to mark the part as active then change it and deativate it. I think I would gain a lot of speed if I could tell Inventor not to update the screen during this process.
Does anyone know how to do this?
ThisApplication.StatusBarText = "BOMAudit "
Dim oDoc As Document = ThisDoc.Document
Dim oCompDef As Inventor.ComponentDefinition = oDoc.ComponentDefinition
Dim oCompOcc As Inventor.ComponentOccurrence
doc = ThisDoc.Document
For Each oCompOcc in oCompDef.Occurrences
	voCompOcc = Component.InventorComponent(oCompOcc.Name)
	If oCompOcc.Suppressed = True Then 'Check for suppressed files without Default BOM Structure
		Component.IsActive(oCompOcc.Name) = True
		oCompOcc.BOMStructure = BOMStructureEnum.kReferenceBOMStructure
		Component.IsActive(oCompOcc.Name) = False
	Else
		Component.IsActive(oCompOcc.Name) = True 'Turn on to allow for update
		oCompOcc.BOMStructure = BOMStructureEnum.kDefaultBOMStructure
	End If
Next
3 REPLIES 3
adam.nagy
Hi there,
There are a few ways that you might be able to speed up your code, including:
StartGlobalTransaction, Application.ScreenUpdating, Application.AssemblyOptions.DeferUpdate
Here is Brian's class on this topic where you can find the above things too:
http://aucache.autodesk.com/au2012/sessionsFiles/3547/4363/handout_3547_CP3547-InventorAPIOddsAndEnd...
Cheers,
Adam Nagy
Autodesk Platform Services
in reply to: adam.nagy
Thanks Adam!
Using StartGlobalTransaction helped a ton. I combined that with stopping the screen from updating and I was able to take the average run time from 152.812s to 48.008s.
You can also check:
InventorApp.UserInterfaceManager().UserInteractionDisabled.
I got very good results disabling user input together with the other options already mentioned in Adam post.
Regards
Fabio
