Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Default IVB location
5 REPLIES 5
291 Views, 5 Replies
Hi all
A few quick questions regarding a company setup: can I have a default.ivb
setup on the server and each workstation's IV setup to look for it on the
network? Are there any drawbacks? Or should I have a default.ivb for each
machine?
In case there are no drawbacks to a network setup, in order for the BMP's to
available as icons, should they be in the same directory as default.ivb?
Having a central place to put default.ivb would make maintenance much
easier...
______________
Rui
ruivaz@cadmais.pt
www.cadmais.pt
5 REPLIES 5
You might do a search for a subject "weird shared default.ivb" I
don't know if anything has changed since that thread or not.
Kent Keller
http://www.MyMcad.com/KWiK/Mcad.htm
Assistant Moderator
Autodesk Discussion Forum Moderator Program
"Rui" wrote in message
news:CC83ABE1A16B4F9EAE07B0079C4FB392@in.WebX.maYIadrTaRb...
> Hi all
default.ivb
the
> network?
Thanks Kent.
I'm going to give it a try since I know what to look for now ......
______________
Rui
ruivaz@cadmais.pt
www.cadmais.pt
"Kent Keller" wrote in message
news:9EF7FC533FF40D6814981602F10AB738@in.WebX.maYIadrTaRb...
> Kent Keller
> Assistant Moderator
> > Hi all
> default.ivb
> the
> > network?
There was a "fix" for Inventor 8 that allows multiple access to a single
.ivb file. If the .ivb is writable, then the first person that accesses it
will have read-write access. Anyone else that uses it will have read-only
access. You could also set the file to be read-only so that everyone will
have read-only access.
Brian Ekins
Developer Technical Services, Autodesk
Discussion Q&A: http://www.autodesk.com/discussion
> Kent Keller
> Assistant Moderator
> > Hi all
> default.ivb
> the
> > network?
Yippie..! Now I can ditch those annoying batch files I make everyone
run...
____________________________________
Sean Dotson, PE
Autodesk Inventor Certified Expert
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Brian Ekins (Autodesk)" wrote in message
news:6B34692917D191C15A064B80BE5806FF@in.WebX.maYIadrTaRb...
it
> Brian Ekins
> > Kent Keller
> > Assistant Moderator
> > > Hi all
> > default.ivb
> > the
> > > network?
Thanks Brian
Customer is still on IV7, but should be upgrading sometime soon.
______________
Rui
ruivaz@cadmais.pt
www.cadmais.pt
it
> Brian Ekins
> > Kent Keller
> > Assistant Moderator
> > > Hi all
> > default.ivb
> > the
> > > network?
