Yippie..! Now I can ditch those annoying batch files I make everyone
run...
____________________________________
Sean Dotson, PE
Autodesk Inventor Certified Expert
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Brian Ekins (Autodesk)" wrote in message
news:6B34692917D191C15A064B80BE5806FF@in.WebX.maYIadrTaRb...
> There was a "fix" for Inventor 8 that allows multiple access to a single
> .ivb file. If the .ivb is writable, then the first person that accesses
it
> will have read-write access. Anyone else that uses it will have read-only
> access. You could also set the file to be read-only so that everyone will
> have read-only access.
> Brian Ekins
> Developer Technical Services, Autodesk
> Discussion Q&A: http://www.autodesk.com/discussion
> "Kent Keller" wrote in message
> news:9EF7FC533FF40D6814981602F10AB738@in.WebX.maYIadrTaRb...
> > You might do a search for a subject "weird shared default.ivb" I
> > don't know if anything has changed since that thread or not.
> > Kent Keller
> > http://www.MyMcad.com/KWiK/Mcad.htm
> > Assistant Moderator
> > Autodesk Discussion Forum Moderator Program
> > "Rui" wrote in message
> > news:CC83ABE1A16B4F9EAE07B0079C4FB392@in.WebX.maYIadrTaRb...
> > > Hi all
> > > A few quick questions regarding a company setup: can I have a
> > default.ivb
> > > setup on the server and each workstation's IV setup to look for it on
> > the
> > > network?
