Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Dear Gurus :)
4 REPLIES 4
145 Views, 4 Replies
Dear Gurus :)
To start this thread, I'm going to ask a simple question 🙂
How complicated is it to pass a text value from excel into a custom
iproperty in Inventor?
It stinks that parameters have to be numbers. I can't link parameters to the
spreadsheet because some of the values are text.
Replies are much appreciated!
4 REPLIES 4
It is pretty simple when you use VB/VBA/.Net, BUT excel spreadsheets use different objects with each version. So to make an application universal and work in the long run, it is easier to use TAB delimited files containg all needed information. They can be opened by Excel straight away for editing if you like, and are easy to read/handle by your app.
Thanks for the pointer. I really appreciate it. Would you happen to know of
any good resources for Inventor VBA? Tutorials, WEBinars, books, etc.?
Thanks again.
wrote in message news:5867970@discussion.autodesk.com...
These groups and the Inventor help should do it. To get started (not tested):
Private Sub GetText()
'create a textfile that has multiple lines
'each line starts with the property name
'then a TAB (chr(9)) then the property value
Dim FileContents As String
FileContents = ReadFile("c:\Myfile.txt")
Dim Lines() As String
Dim Vals() As String
Lines = Split(FileContents, vbCrLf)
For Each Line In Lines
Vals = Split(Line, Chr(9))
If Vals(0) = "MyPropName" Then
Debug.Print "Prop value: " & Vals(1)
'grab the property in inventor and fill in the value
Next
End Sub
Private Function ReadFile(FileName As String) As String
'requires a reference to the Windows Script Host Object Model
Dim FSO As New FileSystemObject
Dim tsInput As TextStream
Dim strLine As String
Set tsInput = FSO.OpenTextFile(FileName, 1)
Dim FileStr As String
Do While Not tsInput.AtEndOfStream
strLine = tsInput.ReadLine
FileStr = FileStr & strLine
Loop
tsInput.Close
Set FSO = Nothing
ReadFile = FileStr
End Function
Thanks again!
wrote in message news:5868237@discussion.autodesk.com...
tested):
Next
End Sub
Loop
tsInput.Close
Set FSO = Nothing
ReadFile = FileStr
End Function
