Cutting hole in a Surface
3 REPLIES 3
407 Views, 3 Replies
Create a Surface by Open profile Extruded.
Create a Solid Cylinder by Circle extruded.
Can we cut a hole in the Surface using the Cylinder?
This is not possible interactively.
Can we use TransientBrep? ImprintBodies?
Tags (1)
3 REPLIES 3
Vladimir.Ananyev
This is possible interactively:
I used Trim operation.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
in reply to: Vladimir.Ananyev
Thanks a lot.
I could get programmatic equivalent as well....as below ..see if its ok/correct (or can it be better)
Sub Split()
    Dim oDoc As PartDocument
    oDoc = _invApp.ActiveDocument
    Dim oCompDef As PartComponentDefinition
    oCompDef = oDoc.ComponentDefinition
    'arguments
   Dim oWS1 As WorkSurface
   oWS1 = oCompDef.WorkSurfaces(1)
   Dim cntws As Integer = oCompDef.WorkSurfaces.Count
    Dim oObjColl As ObjectCollection
    oObjColl = _invApp.TransientObjects.CreateObjectCollection()
    Dim cntsrf As Integer = oCompDef.SurfaceBodies.Count
    Dim oSurface As SurfaceBody 'WorkSurface
    oSurface = oCompDef.Features.ExtrudeFeatures.Item("ExtrusionSrf1").SurfaceBodies.Item(1)
    Dim cntsrffa As Integer = oSurface.Faces.Count
    Dim oSolid As SurfaceBody 'Cylinder
    oSolid = oCompDef.SurfaceBodies.Item(1)
    Dim oFace As Face
    For Each oFace In oSurface.Faces
        oObjColl.Add(oFace)
    Next
    Dim oSplit As SplitFeature
    oSplit = oCompDef.Features.SplitFeatures.SplitFaces(oSolid, False, oObjColl)
    Dim oFaceColl As FaceCollection
    oFaceColl = _invApp.TransientObjects.CreateFaceCollection
    Dim orFace As Face = oSurface.Faces.Item(1) ' hardcoded for test
    oFaceColl.Add(orFace)
    ' can I avoid following extra feature call
    Dim oDeleteFace As DeleteFaceFeature
    oDeleteFace = oCompDef.Features.DeleteFaceFeatures.Add(oFaceColl)
    oCompDef.SurfaceBodies.Item(1).Visible = False
End Sub
adam.nagy
Shame it does not seem possible to create a TrimFeature (that Vladimir used in the UI) through the API.
If you go with SplitFeature, I guess you'll have to delete the face by yourself, as you are doing it now.
Adam Nagy
Autodesk Platform Services
