Customising Measure Tool
4 REPLIES 4
sanjaysy
427 Views, 4 Replies
Whenever we use measure tool it will show the a dialog box with valves of x,y,z, delta X, delta Y & delta Z. I want to customize the same as per the attached image.
Customize this, dialog box will not disappear(modal) after entering into any other command so no need to remember the values of x,y....etc.
Sanjay Yallure
Inventor Professional 10.0
Sanjay
4 REPLIES 4
in reply to: sanjaysy
HEllo Sanjay,
Did you get that macro done, customising the measure tool???
I need a tool to measure from face to workpoint.
Can you please help me??
Amool.
adam.nagy
Inventor dialogs are not customizable in general. However you can create your own dialog if you want to.
The measure functionalities are available through the API, so that part of it you could reuse.
Adam Nagy
Autodesk Platform Services
in reply to: adam.nagy
HEllo Adam,
I am writing a macro to get distances of "WorkPoint"s in Occurrences from "Face"s of parts in occurrences.
And writing all data to excel file or csv file.
Thanks.
AD
xiaodong_liang
well, WorkPoint.Point has the method Point.DistanceTo to get the distance of two work points.
As to writting to Excel/CSV, you can just use Windows API. Searching with the keywords, you could also find some posts here.
