Have a Custom Content Center had three new parts added to the table, the table is correct the file in vault is correct , the part when originally is dropped into the asssembly is the correct size , .......but when I refresh the tables for the assembly the sizes change to some other values that match other parts in the table and then the parts dont match what I originally put into the table.
This will most-likely be because you've edited the table using the "Edit via Spreadsheet" (Excel) option and somehow copied the hidden column values into your new part row. I know because I've done this myself by accident in the past.
When editing the table using Excel it's best to always add new items at the bottom. You can then sort the table to get things back in the correct order once you return to the Inventor dialogue.
Also when using Edit via Excel in the Family. Don't edit any values in blue columns.
Scott Moyse
Design & Manufacturing Technical Services Manager at Cadpro New Zealand
Co-founder of the Grumpy Sloth full aluminium billet mechanical keyboard project
