My two folders for loading custom add-ins into Inventor are not there. Specifically, I'm trying to put a .addin file into C:\ProgramData\Autodesk\Inventor Addins\, but the last folder is absent. Is there something else that has to be installed for this to be available and functional? This is a relatively new install, and I haven't found any information on this issue.
Mike
Solved by rossano_praderi. Go to Solution.
Hi Mike,
if you would like to use this path "C:\ProgramData\Autodesk\Inventor Addins\" and on the target Pc is absent, just create it manually or with your code.
There is nothing more to install.
Check this post for default addin paths
http://forums.autodesk.com/t5/inventor-customization/where-to-place-inventor-addin/td-p/3314019
Bregs
Rossano Praderi
C:\ProgramData\Autodesk\ApplicationPlugins is where all of my AutoCAD bundles currently reside. I'm trying to get Inventor plugins to load, and Inventor doesn't seem to read from that folder. I went ahead and manually created the InventorAddins folder, and that is working for me.
Thanks for all the help,
Mike
