HEllo
I am just discovering the Ilogic feature, and i was wondering if we can create a table and importing some datas from other files in it.
This is for idw, as we are using 1 file per drawing i would like to make a summary of all my project's drawing into the first page.
I was looking for some information about creating a table and has not found any good thing.
I don'T want to use Excel at all for that.
If anyone could send me some link with ressources it would be really nice
Thank you
Solved by dkatz. Go to Solution.
The only way I could do that was to add virtual parts to a parts list. Hide the default parts and add your info as virtual parts.
http://blog.ads-sol.com/2014/08/info-table-in-drawing.html
you could just make your own custom table (instead of a parts list) and pull parameters and iprops in programmatically. Here's the example from the Autodesk Programming help (I converted it over for iLogic use, as I'm sure many others have).
Public Sub CreateCustomTable() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument oDrawDoc = ThisApplication.ActiveDocument ' Set a reference to the active sheet. Dim oSheet As Sheet oSheet = oDrawDoc.ActiveSheet ' Set the column titles Dim oTitles(0 To 2) As String oTitles(0) = "Part Number" oTitles(1) = "Quantity" oTitles(2) = "Material" ' Set the contents of the custom table (contents are set row-wise) Dim oContents(0 To 8) As String oContents(0) = "1" oContents(1) = "1" oContents(2) = "Brass" oContents(3) = "2" oContents(4) = "2" oContents(5) = "Aluminium" oContents(6) = "3" oContents(7) = "1" oContents(8) = "Steel" ' Set the column widths (defaults to the column title width if not specified) Dim oColumnWidths(0 To 2) As Double oColumnWidths(0) = 2.5 oColumnWidths(1) = 2.5 oColumnWidths(2) = 4 ' Create the custom table Dim oCustomTable As CustomTable oCustomTable = oSheet.CustomTables.Add("My Table", ThisApplication.TransientGeometry.CreatePoint2d(15, 15), _ 3, 3, oTitles, oContents, oColumnWidths) End Sub
So then you could fill out the contents with iproperties/paramters from the part using something like this: http://forums.autodesk.com/t5/inventor-general-discussion/using-ilogic-to-retrieve-iproperties-form-...
Hope that gets you somewhere closer.
I have looked long and hard to create a custom table, I didn't wanted to touch the parts list but that's the only way I found.
The code seems fine except it creates a new table everytime. Need to check if table exists, update if yes, create if not.
Thanks.
TableCount = 0 numtables = oSheet.CustomTables.Count ' VB Code to count the number of custom tables on the page If numtables > 0 Then For i = numtables To 1 Step -1 TableTitle = oSheet.CustomTables.Item(i).Title If TableTitle = "My Table" Then TableCount = TableCount + 1 End If Next End If
You'll find this snippet to be useful for determining if you have a table already. Ive used the title as the way of distinguishing one table from another.
Thank you all of you for the information, I had no time yet to set some code lines, as soon as I will start it and I will all let you know.
I have also found some old code from inv 11 (I have relaese 2015) using commands like "set" or some other commands that are not anymore in use.
I didn't got your message; for some reason I don't get emails all the time.
I will need to check if a custom table has been placed allready, I am having as much as 3 custom tables on some drawings.
