Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Creating Drawings automatic
1 REPLY 1
christopher.johns
452 Views, 1 Reply
I have created an I-factory of Parts and I have a master drawing ready. I am trying find something that will create drawings for every member of the I-factory.
1 REPLY 1
If you put the first iPart member to the 1st drawing sheet,
then the following VBA macro could create sheets for all other members
using method shown in this video
 http://www.youtube.com/watch?v=7Y2lgdPf7dM
Sub iPartMembersDrawings()
    Dim oDrawDoc As DrawingDocument
    Set oDrawDoc = ThisApplication.ActiveDocument
    'Set a reference to the 1st sheet - master
    Dim oMasterSheet As Sheet
    Set oMasterSheet = oDrawDoc.Sheets.Item(1)
    'reference to the base view (assume it is the 1st view)
    Dim oMasterView As DrawingView
    Set oMasterView = oMasterSheet.DrawingViews.Item(1)
    'reference to the referenced part
    Dim oDoc As Inventor.PartDocument
    Set oDoc = oMasterView.ReferencedDocumentDescriptor.ReferencedDocument
    Call oDoc.Update
        Dim oFactory As iPartFactory
        Dim oMember As iPartMember
        Dim MemberName As String
        Dim oTargetSheet As Sheet
        Dim oTargetView As DrawingView
        Dim i As Integer
    'part definition
    Dim oCompDef As PartComponentDefinition
    Set oCompDef = oDoc.ComponentDefinition
    If oCompDef.IsiPartMember Then
        'this is iPart member
        Set oMember = oCompDef.iPartMember
        MemberName = oMember.Row.MemberName
        'reference to the factory object
        Set oFactory = oMember.ParentFactory
        'loop through the factory table rows 2..Count
        For i = 2 To oFactory.TableRows.Count
            'create new sheet
            Set oTargetSheet = AddNewSheet_Using_Command(oMasterSheet)
            ' copy all views from Master sheet to the new sheet
            Call CopyAllDrawingViews(oMasterSheet, oTargetSheet)
            ' base view on the target sheet
            Set oTargetView = oTargetSheet.DrawingViews.Item(1)
            MemberName = oFactory.TableRows.Item(i).MemberName
            oTargetView.ActiveMemberName = MemberName
            'show member name in the view's label
            'for debugging purposes only
            oTargetView.Label.FormattedText = MemberName
            oTargetView.ShowLabel = True
            oTargetSheet.Update
        Next i
    Else
        MsgBox "Put the 1st member to the 1st sheet"
    End If
    Beep
End Sub
Function AddNewSheet_Using_Command(ByRef oSourceSheet As Sheet) As Sheet
    Dim oDoc As DrawingDocument
    Set oDoc = oSourceSheet.Parent
    Dim oCopyCmd As ControlDefinition
    Set oCopyCmd = ThisApplication.CommandManager.ControlDefinitions.Item("DrawingNewSheetCtxCmd")
    oCopyCmd.Execute
    Set AddNewSheet_Using_Command = oDoc.Sheets.Item(oDoc.Sheets.Count)
End Function
Sub CopyAllDrawingViews(ByRef oSourceSheet As Sheet, _
                        ByRef oTargetSheet As Sheet)
    oSourceSheet.Activate
    ' Select all the views to copy
    oDoc.SelectSet.Clear
    Dim oView As DrawingView
    For Each oView In oSourceSheet.DrawingViews
        Call oDoc.SelectSet.Select(oView)
    Next
    ' Execute the copy command
    Set oCopyCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppCopyCmd")
    Call oCopyCmd.Execute
    ' Activate and select the destination sheet
    oTargetSheet.Activate
    oDoc.SelectSet.Select oDoc.ActiveSheet
    ' Execute the paste command
    Dim oPasteCmd As ControlDefinition
    Set oPasteCmd = ThisApplication.CommandManager.ControlDefinitions.Item("AppPasteCmd")
    Call oPasteCmd.Execute
End Sub
Hope this helps.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
