In an assembly of a gymnasium divider curtain, I create a path on a 3D sketch which snakes its way upward through a series of grommets. A circular profile is then swept along the path to create a new part - a cable. The cable is its own unique part document and is saved and then vaulted in a job-specific folder. The curtain assembly has several instances of this cable. Everything looks fine until the assembly is closed and later opened for editing. When the assembly is opened, the cables show up in the browser as "Unresolved." Graphically, they have disappeared. Any ideas as to why?
Thanks in advance.
Windows 7 Professional, 64-bit
Inventor 2013 / Vault Collaboration 2013
Solved by larry.daubenspeck. Go to Solution.
Looking into this further, the 3D sketch seems to be the culprit. A similar gym divider using belts instead of cables shows none of these problems, when both get created from scratch for each location. Upon review of the source code, I realized the belts get created on a planar sketch. I converted the cable's 3D sketch into a planar sketch, and the problem seems to have disappeared.
