Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Create sketch on flat pattern
1 REPLY 1
mk92
238 Views, 1 Reply
is there a way to create a sketch on the flat pattern with iLogic?
Regards
Tags (1)
1 REPLY 1
adam.nagy
in reply to: mk92
If you can figure out how to get to the face of the flat pattern you want to create the skecth on then it should be possible.
If it's e.g. the base face you need that should be easy: you just need SheetMetalComponentDefinition.FlatPattern.Sketches.Add and SheetMetalComponentDefinition.FlatPattern.BaseFace
The best thing is to try to figure this out in VBA then migrate the code to iLogic once you know how it's done:
http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
Cheers,
Adam Nagy
Autodesk Platform Services
