If you can figure out how to get to the face of the flat pattern you want to create the skecth on then it should be possible.
If it's e.g. the base face you need that should be easy: you just need SheetMetalComponentDefinition.FlatPattern.Sketches.Add and SheetMetalComponentDefinition.FlatPattern.BaseFace
The best thing is to try to figure this out in VBA then migrate the code to iLogic once you know how it's done:
http://adndevblog.typepad.com/manufacturing/2013/10/discover-object-model.html
Cheers,
