Hi everyone,
recently, I've made a couple of global forms to fill out only the iproperties we use and its working great. I'm now trying to make one using vb.net that allows us to choose the material shape, type and size to give us at the end a Stock number. It's working great the only problem I have is to transfer that Stock Number to the inventor Stock Number. When I click the create rule for a dialog button and select my .dll nothing there is 1 item in each list. When I click ok it generates the code to show my dialog. Any clue of what I am doing wrong?
I've added the vb.net files in attachment. The program won't work since you don't have the excel files and I can't send them to you...
*I changed the extension of the file to dwg so I could post it to you, just change it to .zip and you should be able to open it..
