Inventor Customization
Lance_White
Message 1 of 12 (2,021 Views)
Create Multi-value parameter with iLogic
2021 Views, 11 Replies
05-01-2012 06:58 AM
Is there a way to create a multi-value parameter with ilogic?
Lance W.
Inventor Pro 2013 (PDS Ultimate)
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
I use something like this ::
Imports Inventor.UnitsTypeEnum
Dim oPartDoc As Document
oPartDoc = ThisDoc.Document
If oPartDoc.DocumentType = kPartDocumentObject Then
Dim oPartCompDef As PartComponentDefinition oPartCompDef = oPartDoc.ComponentDefinition
Dim oParams As Parameters oParams=oPartCompDef.Parameters Dim oUserParams As UserParameters oUserParams=oParams.UserParameters Dim oAwesomeParameter As Parameter Try otester = oUserParams.Item("AwesomeParameter") Catch oInsulationType=oUserParams.AddByValue("AwesomeParameter", "Option1", kTextUnits) MultiValue.SetList("AwesomeParameter", "Option1", "Option2", "Option3", "Option4") End Try End If Parameter.Param("AwesomeParameter").ExposedAsProperty = False Parameter.Param("AwesomeParameter").IsKey = True
 Also. A list of enums (for unit types) :
Public Enum UnitsTypeEnum
kUnitlessUnits = 11265
kDefaultDisplayLengthUnits = 11266
kDatabaseLengthUnits = 11267
kCentimeterLengthUnits = 11268
kMillimeterLengthUnits = 11269
kMeterLengthUnits = 11270
kMicronLengthUnits = 11271
kInchLengthUnits = 11272
kFootLengthUnits = 11273
kYardLengthUnits = 11274
kMileLengthUnits = 11275
kDefaultDisplayAngleUnits = 11276
kDatabaseAngleUnits = 11277
kRadianAngleUnits = 11278
kDegreeAngleUnits = 11279
kGradAngleUnits = 11280
kDefaultDisplayMassUnits = 11281
kDatabaseMassUnits = 11282
kKilogramMassUnits = 11283
kGramMassUnits = 11284
kSlugMassUnits = 11285
kLbMassMassUnits = 11286
kOunceMassUnits = 11287
kDefaultDisplayTimeUnits = 11288
kDatabaseTimeUnits = 11289
kSecondTimeUnits = 11290
kMinuteTimeUnits = 11291
kHourTimeUnits = 11292
kDefaultDisplayTemperatureUnits = 11293
kDatabaseTemperatureUnits = 11294
kKelvinTemperatureUnits = 11295
kCelsiusTemperatureUnits = 11296
kFahrenheitTemperatureUnits = 11297
kMetersPerSecondSpeedUnits = 11298
kFeetPerSecondSpeedUnits = 11299
kMilesPerHourSpeedUnits = 11300
kAcreAreaUnits = 11301
kLiterVolumeUnits = 11302
kGallonVolumeUnits = 11303
kQuartVolumeUnits = 11304
kPintVolumeUnits = 11305
kCupVolumeUnits = 11306
kOunceVolumeUnits = 11307
kPascalPressureUnits = 11308
kPSIPressureUnits = 11309
kKSIPressureUnits = 11310
kNewtonForceUnits = 11311
kDyneForceUnits = 11312
kLbForceUnits = 11313
kOunceForceUnits = 11314
kWattPowerUnits = 11315
kHorsePowerPowerUnits = 11316
kJouleWorkUnits = 11317
kErgWorkUnits = 11318
kCalorieWorkUnits = 11319
kBTUWorkUnits = 11320
kRPMAngularVelocityUnits = 11321
kCompositeUnits = 11322
kNauticalMileLengthUnits = 11323
kMilLengthUnits = 11324
kSteradianAngleUnits = 11325
kCircularMilAreaUnits = 11326
kAmpElectricalCurrentUnits = 11327
kVoltElectricalVoltageUnits = 11328
kOhmElectricalResistanceUnits = 11329
kCoulombElectricalChargeUnits = 11330
kFaradElectricalCapacitanceUnits = 11331
kSiemensElectricalConductanceUnits = 11332
kmhoElectricalConductanceUnits = 11333
kWeberMagneticFluxUnits = 11334
kMaxwellMagneticFluxUnits = 11335
kTeslaMagneticInductionUnits = 11336
kGammaMagneticInductionUnits = 11337
kGaussMagneticInductionUnits = 11338
kHenryElectricalInductanceUnits = 11339
kOerstedMagneticInductionUnits = 11340
kHertzFrequencyUnits = 11341
kCandelaLuminousIntensityUnits = 11342
kLumenLuminousFluxUnits = 11343
kLuxIlluminationUnits = 11344
kMoleSubstanceUnits = 11345
kTextUnits = 11346
kBooleanUnits = 11347
End Enum
*Edit : Code formatting will seem a bit strange, but I wanted those lines to be full lines instead of broken!
Valued Mentor
MegaJerk
Message 2 of 12 (2,018 Views)
Re: Create Multi-value parameter with iLogic
05-01-2012 09:36 AM in reply to: Lance_White
  kTextUnits = 11346
End Enum
If my solution seems to remedy your problem, please press the Accept Solution button, -
as it increases my power levels and will eventually help to elevate me towards outer space.
Check out my iLogic injection tool here : http://goo.gl/ce1Qg
Distinguished Mentor
swordmaster
Message 3 of 12 (2,013 Views)
05-01-2012 12:53 PM in reply to: MegaJerk
Not sure if i would have a use for your rule, but i wanted to try it out.
I get a error on the line
oInsulationType
it wants to convert Option1 from a string to a double..........any ideas?
Inventor 2010 Certified Professional
Curtis_Waguespack
Message 4 of 12 (2,008 Views)
05-01-2012 02:48 PM in reply to: swordmaster
Hi swordmaster,
I noticed you stated you're using Inventor 2010.  I'm guessing that is the issue, since Text parameters were not added until Inventor 2011.
As an alternative you might be able to use something like this:
oStringArray = new string(){"Pinched", "Drilled", "Milled (2 step)", "EDM"}
oList = InputListBox("Select a feature type", oStringArray, "Punched", "iLogic", "Available Feature Types")
MessageBox.Show(oList, "ilogic")
I hope this helps.
Curtis
  solution.png  Did you find this reply helpful ? If so please use the Accept as Solution or  Kudos button below.
swordmaster
Message 5 of 12 (1,998 Views)
05-02-2012 05:27 AM in reply to: Curtis_Waguespack
Hello Curtis,
Yes i use inv 2009 (work) and 2010 (home) !
I should have remembered about not being able to create string parameters.
However the original question was "how to create multi-value parameters with ilogic" and I can create a
ilogic parameter from the ilogic parameter editor , this allows me to choose from types User, String or Boolean.
So i believe the code will work with a little "tweaking" so that it creates a ilogic not a user parameter
thanks for the reply :smileyhappy:
Lance_White
Message 6 of 12 (1,997 Views)
05-02-2012 05:31 AM in reply to: Lance_White
Thanks, that helps a lot. I knew how to make a text parameter and for some reason thought that it had to be a multi-value list at creation. it never occured to me to try just adding the list afterwards.
Lance W.
Vault Pro 2013
Windows 7 64
Xeon 2.4 Ghz 12GB
Distinguished Contributor
sergelachance
Message 7 of 12 (1,573 Views)
02-19-2013 06:11 AM in reply to: Lance_White
Hi :smileyhappy:
this rule work really great in text unit but i try to put my new parameter in inch?
This is my try, sorry for my horrible english :smileysad:
but dont work :smileysad:
Thanks for your help :smileyhappy:
Try
otester = oUserParams.Item("ÉPAISSEUR")
Catch
oInsulationType=oUserParams.AddByValue("ÉPAISSEUR", "11/16", kInchLengthUnits)
MultiValue.SetList("ÉPAISSEUR", "1/32", "1/16", "1/8", "1/4", "3/8", "7/16", "1/2", "9/16", "5/8", "11/16", "3/4", "13/16", "7/8", "1", "1 1/4", "1 3/8", "1 1/2")
End Try
End If
Parameter.Param("ÉPAISSEUR").ExposedAsProperty = False
Parameter.Param("ÉPAISSEUR").IsKey = True
sergelachance
Message 8 of 12 (1,566 Views)
02-19-2013 08:38 AM in reply to: sergelachance
another question :smileyhappy:
it'S possible to add a <custom value> in MultiValue.SetList
ex.:
MultiValue.SetList("CHANTS", "AUCUN", "1C", "1L", "1L-1C", "1L-2C", "2L", "2L-1C", "2L-2C", <custom value>)
Thanks all :smileyhappy:
Valued Mentor
MegaJerk
Message 9 of 12 (1,552 Views)
02-20-2013 05:24 AM in reply to: sergelachance
If you want to add an Inch based Multivalue list, then you can do so using this method :
	Try
		otester = oUserParams.Item("InchParameter")
		Catch
		oInsulationType=oUserParams.AddByValue("InchParameter", 1/16*2.54, kInchLengthUnits )
		MultiValue.SetList("InchParameter", 1/16, 3/16, 5/16, 7/16, 9/16)
	End Try
End If
Parameter.Param("InchParameter").ExposedAsProperty = False
Parameter.Param("InchParameter").IsKey = True
If you want to add custom values, you can, BUT they will not work correctly if the parameter itself is of a different unit type! A parameter with kInchLengthUnits, will not enjoy if you select text from the multivalue list (even though it will allow you to put it there).
If you need to add numbers and text, then I would suggest keeping kTextUnits and use a Select Case statement if there will only be a handful of selectable options.
Side note: when you put things in quotes (“11/16” or  “400*2” or “Jimmy”) the compiler interprets that as text input. That is why you were having your problem above.
Side note Part 2 : Do you need to have the value show as “11/16” instead of .6875? If not, then you could just make it a MultivalueList text parameter (“.6875”, “.875”, “Some Text Here”) and use the
IsNumeric(Parameter) method to check if the selection is a valid number or not. Using IsNumeric on an expresion like “11/16” returns false, so if you pre-converted them out of fraction to decimal, it may help you in the long run.
sergelachance
Message 10 of 12 (1,547 Views)
02-20-2013 09:25 AM in reply to: Lance_White
ok i understand, but what is the right rule to tell in my multivalue parameter the <custom value>??
