I would like to add a dimension between a drawingcurve and a workaxis which is included from the 3d model.
I include the axis like this;
DrawingView.SetIncludeStatus(oDModel.rotationAxis, true);
I try to find the DrawingCurve related to this Axis in the drawingview, but some how it doens't work;
foreach (DrawingCurve oCurve in baseDrawingView. DrawingCurves)
if (oCurve.ModelGeometry == oDModel.rotationAxis)
Similar code works for "real" model edges, but it seams that a workaxis requires a different approach.
Any suggestions anybody?
thanks
In attachment you will find test program in VBA for centerline quest. You can find that your centerline is in Thisapplication.ActiveDocument.ActiveSheet.Centerlines(1). In my example there is only one centerline and because of that is ... Centerlines(1).
I hope it will help.
Nedeljko.
