I am looking for any example to create an addin compatible between versions of inventor and also compatible win between 32 and 64bit.
Today I know create all separate. Thereby generating 4 different files...
Example:
Addin2013_32x.dll
Addin2013_64x.dll
Addin2014_32x.dll
Addin2014_64x.dll
Thanks in advanced.
Solved by philippe.leefsma. Go to Solution.
Hi Cristiano,
If you use .Net, then you shouldn't have to worry about 32/64 bit issues. Compiling your add-in with "Any CPU" will be enough.
If you compile a .Net add-in against Inventor 2013 interop, you should be able to have it loaded under 2013 32/64 and 2014 32/64.
I hope it helps.
Philippe.
Somewhere out this project. I remade and now it's all right, thank you.
