Create a Boolean Parameter
9 REPLIES 9
Message 1 of 10
smccoywm
4685 Views, 9 Replies
Does the IV2012 API allow the creation of a Yes/No parameter. If so can someone post an exapmple. I have created "Text" parameters but I am stumped on this one.
Scott A. McCoy
West-Mark Mfg.
9 REPLIES 9
Message 2 of 10
xiaodong_liang
in reply to: smccoywm
Please refer to the following code. Make sure the last argument is "BOOLEAN".
Sub test()
Dim oDoc As PartDocument
Set oDoc = ThisApplication.ActiveDocument
'bool
Dim oUserParam1 As UserParameter
Set oUserParam1 = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Ready", True, "BOOLEAN")
'text
Dim oUserParam2 As UserParameter
Set oUserParam2 = oCompDef.Parameters.UserParameters.AddByValue("Name", "rocky", "TEXT")
'double
Dim oUserParam3 As UserParameter
Set oUserParam3 = oCompDef.Parameters.UserParameters.AddByValue("Length", 5, kCentimeterLengthUnits)
End Sub
Best regards,
Xiaodong Liang
Developer Consultant
Autodesk Developer Technical Services
Message 3 of 10
eljoseppo
in reply to: xiaodong_liang
I made some changes to avoid creating additional parameter like IPE_1, IPE_2 everytime I run my rule:
Try
myParam=Parameter("IPE")
Catch
Dim myParam As UserParameter
myParam = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("IPE", "IPE 000", "TEXT")
End Try
MultiValue.SetList("IPE", "IPE 080", "IPE 100", "IPE 500", "IPE 550", "IPE 600")
 maybe someone will need this later...
Message 4 of 10
eljoseppo
How can I create a parameter in IAM file?
Message 5 of 10
ekinsb
in reply to: eljoseppo
The code above will work if you change the line
to
    Dim oDoc As AssemblyDocument
or you can change it to
    Dim oDoc As Document
and the same program will work in both parts and assemblies.
Brian Ekins
Mod the Machine blog
Message 6 of 10
eljoseppo
in reply to: ekinsb
Thanks it was not so obvious. I tried it before, had some errors, wasn't sure if its the right way. Now I've tried again - code is working in iLogis but afred I delete one line. No idea why.
Try
 myParam=Parameter("TYPE")
Catch
 'Dim myParam As UserParameter
 myParam = oDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("TYPE", "TYPE 0", "TEXT")
End Try
MultiValue.SetList("TYPE", "TYPE 1", "TYPE 2")
 thanks again.
Message 7 of 10
Jefkee
i was wondering if there is a way to add unitless user parameters?
i managed to add length type parameters but i'm unable to create a unitless.
Inventor 2013
Message 8 of 10
eljoseppo
in reply to: Jefkee
Does this work for you:
Dim oPartDoc As Inventor.Document
Set oPartDoc = ThisApplication.ActiveDocument
Set oUserParam3 = oPartDoc.ComponentDefinition.Parameters.UserParameters.AddByValue("Length", 4, kUnitlessUnits)
tested in Inventor 2015
Message 9 of 10
This code is not working for me in AI 2015
" set" is no longer supported and without "set" it doesn't work 😞
Message 10 of 10
eljoseppo
in reply to: JorisSteurs1246
"set" is working only in VBA editor
which code is not working? This one?:
Try
Catch
End Try
