Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Copy Drawing Views to New Drawing Template
6 REPLIES 6
johnster100
1623 Views, 6 Replies
Hi There,
I've recently made a new drawing template with ilogic prompts for entering data for all fields within the template. It also sets view sizes etc.
I have lots of master drawings, which are reused when sizes etc change for a contract, which i would like to transfer to this new template. Drawing Resource Transfer Wizard does not offer this function.
Is there any API code which would do this for me? Ideally I could get all drawings in a folder copied to specific sheet size on the master template.
As the template will probably be developed further in the future I'm very loathed to do this take manually.
thanks,
John
6 REPLIES 6
Hi John,
Does "DrawingView.CopyTo" method addresses your query? Please take a look at the API Help Files if you need more details.
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
thanks for the reply. This may help, I'm not entirely sure how to use it. Is there any examples anyway? I have code to loop though each view but i don't know how to copy to another sheet in another file
Dim oDrawDoc As DrawingDocument = ThisApplication.ActiveDocument
oSheets = oDrawDoc.Sheets
For Each oSheet In oSheets
   oViews = oSheet.DrawingViews
     For Each oView In oViews
             oView.CopyTo("what goes in here?")
     Next
Next
thanks,
John
in reply to: johnster100
It wants a Sheet object like this:
Set oDrawDoc = ThisApplication.ActiveDocument
Dim oNewDoc As Inventor.DrawingDocument
Set oNewDoc = ThisApplication.Documents.Open("C:\New Drawing Document.IDW", True)
Dim oSheets As Sheets
Set oSheets = oDrawDoc.Sheets
Dim oViews As DrawingViews
Dim oView As DrawingView
Dim oSheet As Sheet
   Set oViews = oSheet.DrawingViews
             oView.CopyTo oNewDoc.Sheets(1)
     Next
Next
johnster100
Thanks Robert,
that works pretty well.
Only problem is that if the view has a section view it seems to jump out. Is there a way to copy the view and all views contained within that view? A sort of copy all function?
thanks,
John
This doesn't seem to be possible, even through the UI; when I select a section view the copy command is immediately greyed out.  In theory you could create a new sketch and section view in the new drawing then recreate any annotations and dimensions all based off the source drawing, but this would be rather complicated for a relatively simple task.
You could copy the entire sheet to the new template as shown below then replace any titleblocks, borders, etc as required.
oSheet.CopyTo oNewDoc
johnster100
Hi Guys,
Copying the sheet worked a treat.
It would be nice if I could also copy over the iproperties from the original to the new drawing (description, drawing number etc). Is there anyway you can loop through the iproperties and set them?
Somethink like this?
for each iproperty in iproperties
    try
         newDrawing.Iproperty(Iproperty.Name) = oldDrawing.Iproperty(Iproperty.name)
    catch
         'new drawing does not contain property with this name
    end try
next
I've had a look through the forum and not came across anything.
thanks again,
John
