Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Copy Design Error
2 REPLIES 2
505 Views, 2 Replies
Copy Design Error
I have an assembly that I created a form for. In that form I allowed the user to "Copy Design". I used this form in a couple of different places but recently I've got an error see the attached picture for the error message. I've done a little research and it seems that the "property set" it's looking for is the "custom" propety tab iproperties? If this is the case how do I get the code to recognize that the tab is actually there(it has been there the whole time) I don't know why it can't find the tab in iproperties.
2 REPLIES 2
xiaodong_liang
it is rare issue I have never heard. The only possibility I can guess is this propertyset is removed by a program.
In any case, you can always add try-catch with your code. e.g.
Dim oPS as PropertySet
try
oPS = Document.PropertySets("{D5CDD505-2E9C-101B-9397-08002B2CF9AE}")
catch
' if it failed to get custom property set, the code will run here.
end try
in reply to: xiaodong_liang
I think that is going to work but now I'm getting the attached error. How do I fix it? here is my code I used your code in line 52:
Imports System
Imports System.IO
'[ ¸.•´¯`•.¸_¸.•´¯`•.¸||Copy Files To New Directory||¸.•´¯`•.¸_¸.•´¯`•.¸
'Copies children files (parts, assemblies and drawings) to same folder (..\..\Drawings for .idw's) as the top assembly
'Notes: Turn debugMsgs to True for some simple messages that walk through some of the process.
'Version: V2.0.1 06/26/2013
Sub Main()
'[=====Declarations=====
Dim oDoc as Inventor.AssemblyDocument
oDoc = ThisDoc.Document
Dim debugMsgs as Boolean = True 'Set to true to display debugging messages. Currently only show messages from the drawing copy and replace portion of the rule.
Dim prereqInfo As Boolean = True'Determines if the required info has been entered
runCount = 0
' Prevents the included code from running unless project and flow numbers are present, and it hasn't been copied to a new location yet
If prereqInfo = True And Parameter("isCopied") = False Then
                      Dim oFileMgr As FileManager
                      Dim oAsmCompDef as AssemblyComponentDefinition
                      oAsmCompDef = oDoc.ComponentDefinition
                        cLocs.masterLoc = Parameter("masterLocation") & "MODELS\"
                        oldDwgLocation = Parameter("masterLocation") & "DRAWINGS\"
                        cLocs.newLoc = ThisDoc.Path
                        cLocs.mLocLen = Len(cLocs.masterLoc)
                      Call ThisApplication.FileManager.RefreshAllDocuments
                        'Call CreateFolders(masterLoc, newLoc)
						Try
						Catch
                     Call CopyFiles(oDoc)', masterLoc, newLoc) 'Call the copy function on this document. It copies all of the referenced files into the same directory as oDoc.
                      	End Try
                  '    Dim files As String
                  '     oDoc.Save2
'[=====Copy Drawings Over=====
    Dim oProjNum As String = Parameter("projectNum")
   	Dim oFlowNum as String = Parameter("flowNum")
    Dim oProjAbbr As String = Parameter("projectAbbr")
    Dim oProjRev As String = Parameter("projectRev")
    Dim oProjYear As String = Parameter("projectYear")
    Dim oProjSEQ As String = Parameter("projectSEQ")
    Dim oProjDes as String = Parameter("projectDesignation")
    Dim oDwgDoc as DrawingDocument
    Dim oPropDoc as Document
    Dim oNVM As NameValueMap
    oNVM = ThisApplication.TransientObjects.CreateNameValueMap
   'oNVM.Add("DeferUpdates", True)
    Dim oFileDesc as FileDescriptor
    'Loop through all files in the old drawing directory, check if they are .idw, copy them to the destination folder, then loop through all of the part/assembly references
    'in the new drawings and determine the proper replacements
    'oldDwgLocation = Parameter("dwgLocation")
    newDwgLocation = System.IO.Path.GetFullPath(ThisDoc.Path & "..\..\..\..\..\Drawings\")
      dwgFolder = System.IO.Directory.GetFiles(oldDwgLocation)
    a = 1
    ' Loops through each file in the target directory and copies all of the files over to the new directory
    For Each targetFile As String In dwgFolder
            targetFileName = System.IO.Path.GetFileNameWithoutExtension(targetFile) 'Get file name of target file
        targetFileExt = System.IO.Path.GetExtension(targetFile) 'Get file extension of target file
            If debugMsgs Then MsgBox("Target Drawing File: " & targetFile)
        Dim isDrawing as Boolean = False
        'Copies all of the drawing files in the folder over to the new folder
             If targetFileExt = ".idw" Then
                  'Replace the
                  If targetFileName.Contains("XXXXXXXX-XX") Then
                        newDwgName = targetFileName.Replace("XXXXXXXX-XX", oProjNum & oFlowNum & "-" & oProjSEQ) & targetFileExt
'                 Else If targetFileName.Contains("XXXXXXXX") Then
'                       newDwgName = targetFileName.Replace("XXXXXXXX", oProjNum & oFlowNum) & targetFileExt
                  Else
                        newDwgName = targetFileName & targetFileExt
                  End If
            If Not System.IO.File.Exists(newDwgLocation & newDwgName) Then
                        If debugMsgs Then MsgBox("COPYING: " & newDwgLocation & newDwgName)
                        ' MsgBox("COPYING: " & newDwgLocation & newDwgName)
                Call ThisApplication.FileManager.CopyFile(targetFile, newDwgLocation & newDwgName)'If file doesn't already exist, copy file to new location
              ' isDrawing = True
            Else
                        If debugMsgs Then MsgBox("Already Copied DRAWING: " & newDwgLocation & newDwgName)
            End If
            Dim fInfo As FileInfo = New FileInfo(newDwgLocation & newDwgName)
            If fInfo.IsReadOnly = True Then fInfo.IsReadOnly = False
                  oDwgDoc = ThisApplication.Documents.OpenWithOptions(newDwgLocation & newDwgName, oNVM, False) 'Invisibly opens file to edit descriptions
                  'Loop through all of the referenced files in the drawing document, and look for the new filename by looking at all of the part/assembly files' OldName iProperties field
                  For Each oFileDesc in oDwgDoc.File.ReferencedFileDescriptors 'For all of the file references in the drawing
                        lookingFor = System.IO.Path.GetFileName(oFileDesc.FullFileName) 'Get the name only of the part we want to replace
                  '     MsgBox("DRAWING: " & oFileDesc.FullFileName)
                        If debugMsgs Then MsgBox("Looking For: " & lookingFor)
                  '     MsgBox(ConvertToNew(lookingFor, oDoc))
                        If lookingFor <> iProperties.Value("Custom", "OldName") Then 'If the file being looked for is not this assembly, look for it in the other file references
                              newFoundFile = ConvertToNew(lookingFor, oDoc)
                        Else
                              If debugMsgs Then MsgBox("This assembly is it")
                              newFoundFile = ThisDoc.PathAndFileName(True)
                        End If
                        If debugMsgs Then MsgBox("Found it:" & newFoundFile)
                        If newFoundFile <> "" Then 'If there is a file, then replace the current reference
                              oFileDesc.ReplaceReference(newFoundFile)
                        Else
                  '         MsgBox("The file """ & lookingFor & """ referenced in drawing """ & oDoc.FullFileName & """ could not be found. Please repair this reference.")
                        End If
                  Next
            '     MsgBox(newDwgLocation & newDwgName)
            Else
            If debugMsgs Then MsgBox("Skipping " & targetFileName)
            Continue For
            End If
            oDwgDoc.Save
            oDwgDoc.Close
            If a = 3 Then Exit For
            a+=1
            Next
']+++++\Copy Drawings Over+++++
Parameter("isCopied") = True 'Sets this to true to prevent rule from accidentally running again
oDoc.Save2
ThisApplication.Documents.CloseAll(True) 'Close all background (read: not visible or interactable documents)
showCompletionMessage = True
End If 'End of the protective IF statement that keeps the rule running W/O project or flow numbers. This allows the design view representations to be repaired.
'[ =====Set Design View Representation back to Default and Associative=====
    'When replacing components, the design view representation may break causing previously hidden planes and other features to be shown. This section resets the
    'design view to Associative and Default. The fileRepTypes list contains the types of files that cause an error because they have no Design View Representation, so
    'the code skips those file types
Dim oOcc as ComponentOccurrence
Dim oAsmCompDefTwo As AssemblyComponentDefinition
oAsmCompDefTwo = oDoc.ComponentDefinition
For Each oOcc In oAsmCompDefTwo.Occurrences 'For every occurrence in the assembly, if the occurrence is an assembly, change its design veiw rep back to Default
    If oOcc.Definition.Type = ObjectTypeEnum.kAssemblyComponentDefinitionObject Then
        oOcc.SetDesignViewRepresentation("Default", "h", True)
    End If
Next
'] +++++/Design View+++++
'[ =====Display Completion Message Box=====
'Allows the Design View Rep to be fixed before the completion message box appears
If Parameter("isCopied") = True And showCompletionMessage = True Then
    i = MessageBox.Show("Copy Design Complete.", "Completed", MessageBoxButtons.OK, MessageBoxIcon.Asterisk, MessageBoxDefaultButton.Button1)
End If
End Sub
Public Class cLibraryLocations
    'Declares oLibraryArray as a "global" variable accessable in the other Sub/Functions by using cLibraryLocations.oLibraryArray
    Public Shared oLibraryArray As New ArrayList
End Class
Public Class cLocs
      Public Shared masterLoc As String' = Parameter.Param("masterLocation")
            Public Shared newLoc as String' = "C:\Users\derek\Desktop\Save As Test\MODELS"
            Public Shared mLocLen As Integer '= Len(cLocs.masterLoc)
            Public Shared relPath
End Class
Private Function ConvertToNew(targetFile As String, containingDoc as Inventor.Document) As String
    'Requires a filename, and an assembly document. Takes the old file name, usually from a drawing reference, loops through all of the files in
    'the top level assembly and looks for the old file name in the new file's iProperties (Custom, OldName) then returns the name of the new file.
    Dim oDocEnum as DocumentsEnumerator
    Dim availDoc as Document
     'MsgBox("LOOKING FOR : " & targetFile)
    For Each oFileDesc in containingDoc.File.ReferencedFileDescriptors 'Look through all of the files in the assembly
        oldFilePath = System.IO.Path.GetDirectoryName(oFileDesc.FullFileName)
            oldFile = System.IO.Path.GetFileName(oFileDesc.FullFileName)
      '  MsgBox(oldFile)
        If oFileDesc.ReferencedFileType = 56327 Then Continue For 'Skip OLE (object linking and embedding) File References such as embedded Excels
        If cLibraryLocations.oLibraryArray.Contains(oldFilePath.ToUpper()) = True Then Continue For 'Skip library parts
        availDoc = oFileDesc.ReferencedFile.AvailableDocuments.Item(1) 'Set reference to the first document in the file (only one document is in a file 99% of the time)
            If debugMsgs Then MsgBox("iproperties: " & iProperties.Value(availDoc.DisplayName, "Custom", "OldName") & " TargetFile: " & targetFile)
            'MsgBox(availDoc.DisplayName)
        If iProperties.Value(oldFile, "Custom", "OldName") = targetFile Then 'If the old filename matches the iProperty
            If debugMsgs Then MsgBox("iproperties: " & iProperties.Value(availDoc.DisplayName, "Custom", "OldName"))
            ConvertToNew = availDoc.File.FullFileName 'Set the reference to the new file
        End If
        'If the document is a subassembly, run this function again on the subassembly to replace the references in that assembly
        If oFileDesc.ReferencedFileType = 56323 Then
            returnFile = ConvertToNew(targetFile, availDoc)
            If returnFile <> "" Then
                If debugMsgs Then MsgBox("assembly returned: " & returnFile )
                ConvertToNew = returnFile
                Return ConvertToNew
            End If
        End If
     If ConvertToNew <> "" Then
        Return ConvertToNew
    End If
    Next
End Function
Private Sub CopyFiles(sourceAssy As Inventor.Document)', masterCopyLoc as String, newCopyLoc As String)
    'This sub takes an assembly document that is passed to it, and copies all of the files referenced within that assembly to the directory that the assembly is saved in. This
    'is meant to be used in cojunction with another rule that saves the assembly to a new location
      Dim projNum as String = Parameter("projectNum")
    Dim oNewFiles as New ArrayList
    Dim subDoc as Document 'An assembly found in the assembly
    Dim oCompOcc as ComponentOccurrence
    Dim oPartCompDef as PartComponentDefinition
    Dim oldFileNames as New ArrayList
      'Dim masterLocation As String = Parameter("masterLocation")
      'Dim mLocLen As Integer = Len(masterLocation)
      masterLocDirs = System.IO.Directory.GetDirectories(cLocs.masterLoc)
    ' Loop through each referenced file in the passed assembly, copy it over to the new project folder, replace the references in the
    ' files with the newly copied files, and run this function again on any assemblies found in the passed assembly
   testEnum = 1
      For Each oFileDesc In sourceAssy.File.ReferencedFileDescriptors
        If oFileDesc.ReferencedFileType <> 56327 Then 'If it is not an Embedded or linked object
            oldFileName = System.IO.Path.GetFileNameWithoutExtension(oFileDesc.FullFileName) 'Collect old file information
            oldFileExt = System.IO.Path.GetExtension(oFileDesc.FullFileName)
                  oldFileRelPath = Mid(oldFilePath,cLocs.mLocLen,1000) & "\"
                  'MsgBox(oldFileRelPath)
                  'projFlowNum = Parameter("projectNum") & Parameter("flowNum") & Parameter("projectSEQ") & "\"
                  oldFileNameExt = oldFileName & oldFileExt
            'newFilePath = cLocs.newLoc & oldFileRelPath
                  newFilePath = cLocs.newLoc & "\"
                  'If Not oldFilePath.Contains("STANDARD PARTS") Then 'Uncomment this and the EndIf to keep the STANDARD PARTS folder parts from being renamed
                        If oldFileName.Contains("XXXXXXXX-XX") Then
                              newFileName = oldFileName.Replace("XXXXXXXX-XX", projFlowNum & "-" & oProjSEQ) & oldFileExt
                        Else If oldFileName.Contains("XXXXXXXX") Then
                              newFileName = oldFileName.Replace("XXXXXXXX", projFlowNum) & oldFileExt
                        Else
                              newFileName = oldFileName & "_" & Parameter("projectNum") & Parameter("flowNum") & oldFileExt 'Create new file name
                        End If
                        'MsgBox(oldFileName  & " - " & oldFileExt  & " - " & oldFilePath  & " - " & newFileName & " - " & newFilePath)
                  'End If
                  'MsgBox(newFilePath)
'                 If newFilePath.Contains("XXXXXXXX-XX") Then
'                       newFilePath = newFilePath.Replace("XXXXXXXX-XX", (projFlowNum & "-" & oProjSEQ))
'                 End If
'                 If newFilePath.Contains("XXXX-FILTER") Then
'                       newFilePath = newFilePath.Replace("XXXX-FILTER", projNum & "-FILTER")
'                 End If
                  If Not System.IO.Directory.Exists(newFilePath)
                        'MsgBox("Creating: " & newFilePath)
                        System.IO.Directory.CreateDirectory(newFilePath)
                  End If
            If Not System.IO.File.Exists(newFilePath & newFileName) Then 'If the file doesn't exist
                        'MsgBox(oFileDesc.FullFileName & " - " & newFilePath & newFileName)
                        Try
                              Call ThisApplication.FileManager.CopyFile(oFileDesc.FullFileName, newFilePath & newFileName) 'Copy the file to the new location
                  Catch
                              MsgBox("ERROR COPYING: " & oFileDesc.FullFileName & " - " & newFilePath & newFileName)
                        End Try
                        Dim fInfo As FileInfo = New FileInfo(newFilePath & newFileName)
                        End If
                  End If
            Try
                  'MsgBox("File Desc: " & oFileDesc.FullFileName & vbCrLf & vbCrLf & "New Folder: " & newFilePath & vbCrLf & vbCrLf & "New File Name: " & newFileName & vbCrLf & vbCrLf & "Master Path: " & cLocs.masterLoc & vbCrLf & vbCrLf & "New Path: " & cLocs.newLoc & vbCrLf & vbCrLf & "Relative Path: " & oldFileRelPath )'& "oFileDesc DisplayName: " & availDoc.DisplayName)
                  oFileDesc.ReplaceReference(newFilePath & newFileName) 'Replace the file reference with new copy
                  Catch
                  MsgBox("Error Replacing: " & newFilePath & newFileName & vbCrLf & System.IO.File.Exists(newFilePath & newFileName))
                  End Try
            iProperties.Value(newFileName, "Custom", "OldName") = oldFileNameExt
                  '************ Replaces the iProperty "Part Number" with the project and flow number **************
                  Dim projectNumberString As String
                  Dim iPN As String
                  Dim iPNa As String
                  iPN = iProperties.Value(newFileName, "Project", "Part Number")
                  projectNumberString = projectNum & flowNum & "-" & projectSEQ
                  projectNumberString2 = projectNum & flowNum
                  b = iPN.Contains("XXXXXXXX-XX")
                        If b Then
                              iPN = iPN.Replace("XXXXXXXX-XX",(projectNumberString))
                              iProperties.Value(newFileName, "Project", "Part Number") = iPN
                              'MsgBox("iPN = " & iPN & " AND the file name is " & newFileName & " And the part number iProperty contains the X's: " & b)
                              availDoc.Save
                        Else If b Then
                              iPN = iPN.Replace("XXXXXXXX",(projectNumberString2))
                              availDoc.Save
                        End If
            'If the document is a subassembly, run this whole function again on the subassembly
                subDoc = oFileDesc.ReferencedFile.AvailableDocuments.Item(1)
                  Call CopyFiles(subDoc)
            End If
        End If
    Next
'iLogicVb.RunRule("UPDATE")
End Sub
'[====List of FileTypeEnums=====
'kAssemblyFileType 56323 An Assembly file.
'kDesignElementFileType 56326 A design element file.
'kDrawingFileType 56324 A drawing file.
'kForeignFileType 56327 A foreign file.
'kPartFileType 56322 A part file.
'kPresentationFileType 56325 A presentation file.
'kUnknownFileType 56321 An unknown type Of file.
