Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Copy color from assembly to parts - 2014 / 2015
3 REPLIES 3
GeorgK
348 Views, 3 Replies
Hello together,
a) how could I copy the color of each part of an assembly to the parts?
b) how could I copy the color from a part to another?
Tanky you
Georg
3 REPLIES 3
philippe.leefsma
in reply to: GeorgK
Hi Georg,
You can get the Appearance asset from the ComponentOccurrence or source Part, and copy it into the target Part using code as follow:
Private Sub SetMaterialToPart()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Dim Name As String
  Name = "Copper"
  Dim localAsset As Asset
  On Error Resume Next
  Set localAsset = oDoc.Assets.item(Name)
  If Err Then
    On Error GoTo 0
    ' Failed to get the appearance
    ' in the document, so import it.
    ' Get an asset library by name.
    ' Either the displayed name (which
    ' can changed based on the current language)
    ' or the internal name
    ' (which is always the same) can be used.
    Dim assetLib As AssetLibrary
    Set assetLib = ThisApplication.AssetLibraries _
        .item("Autodesk Material Library")
    'Set assetLib = ThisApplication.AssetLibraries _
    '.Item("AD121259-C03E-4A1D-92D8-59A22B4807AD")
    ' Get an asset in the library
    Dim libAsset As Asset
    Set libAsset = assetLib.MaterialAssets.item(Name)
    ' Copy the asset locally.
    Set localAsset = libAsset.CopyTo(oDoc)
  On Error GoTo 0
  'set material to the part
  oDoc.ActiveMaterial = localAsset
  ' Select the top browser node of the model pane.
  ' This is a workaround to refresh materials info in the UI.
  Call oDoc.BrowserPanes.ActivePane.TopNode.DoSelect
End Sub
Hope that helps,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
GeorgK
in reply to: philippe.leefsma
Hello Philippe,
thank you for the code. But I would like to copy only the color and not the material.
Georg
philippe.leefsma
in reply to: GeorgK
If you want it to be compatible with 2014 and 2015, there is no way you can copy just the color, it is part of the material properties. In that case, you could determine which property in the appearance is defining the color and copy that color property in the target appearance.
Here is some code that will dump the appearance settings:
Public Sub GetAppearanceSettingsToFile()
    Dim doc As PartDocument
    Set doc = ThisApplication.ActiveDocument
    Dim appearance As Asset
    'Set appearance = doc.Assets.item("Rot_Transparent")
    Set appearance = doc.ActiveAppearance
    Dim f As Integer
    f = FreeFile()
    Open "C:\Temp\" & appearance.DisplayName & ".txt" For Output As #f
    Print #f, "Appearance Name: " & appearance.DisplayName
    Dim value As AssetValue
    For Each value In appearance
        PrintAssetValueToFile f, value, 5
    Next
    Close #f
End Sub
Private Function ColorToString(InColor As color) As String
    ColorToString = "[" & InColor.Red & ", " & InColor.Green & ", " & InColor.Blue & ", " & InColor.Opacity & "]"
End Function
Private Sub PrintAssetValue( _
    ByRef inValue As AssetValue, _
    ByRef indent As Long)
    Dim indentChars As String
    indentChars = space(indent)
    Debug.Print indentChars & "Value"
    Debug.Print indentChars & "  DisplayName: " & inValue.DisplayName
    Debug.Print indentChars & "  Name: " & inValue.Name
    Debug.Print indentChars & "  IsReadOnly: " & inValue.IsReadOnly
    Select Case inValue.ValueType
        Case kAssetValueTextureType
            Debug.Print indentChars & "  Type: Texture"
            Dim textureValue As TextureAssetValue
            Set textureValue = inValue
            Dim texture As AssetTexture
            Set texture = textureValue.value
            Select Case texture.TextureType
                Case kTextureTypeBitmap
                    Debug.Print indentChars & "  TextureType: kTextureTypeBitmap"
                Case kTextureTypeChecker
                    Debug.Print indentChars & "  TextureType: kTextureTypeChecker"
                Case kTextureTypeGradient
                    Debug.Print indentChars & "  TextureType: kTextureTypeGradient"
                Case kTextureTypeMarble
                    Debug.Print indentChars & "  TextureType: kTextureTypeMarble"
                Case kTextureTypeNoise
                    Debug.Print indentChars & "  TextureType: kTextureTypeNoise"
                Case kTextureTypeSpeckle
                    Debug.Print indentChars & "  TextureType: kTextureTypeSpeckle"
                Case kTextureTypeTile
                    Debug.Print indentChars & "  TextureType: kTextureTypeTile"
                Case kTextureTypeUnknown
                    Debug.Print indentChars & "  TextureType: kTextureTypeUnknown"
                Case kTextureTypeWave
                    Debug.Print indentChars & "  TextureType: kTextureTypeWave"
                Case kTextureTypeWood
                    Debug.Print indentChars & "  TextureType: kTextureTypeWood"
                Case Else
                    Debug.Print indentChars & "  TextureType: Unexpected type returned"
            End Select
            Debug.Print indentChars & "  Values"
            Dim textureSubValue As AssetValue
            For Each textureSubValue In texture
                Call PrintAssetValue(textureSubValue, indent + 4)
            Next
        Case kAssetValueTypeBoolean
            Debug.Print indentChars & "  Type: Boolean"
            Dim booleanValue As BooleanAssetValue
            Set booleanValue = inValue
            Debug.Print indentChars & "    Value: " & booleanValue.value
        Case kAssetValueTypeChoice
            Debug.Print indentChars & "  Type: Choice"
            Dim choiceValue As ChoiceAssetValue
            Set choiceValue = inValue
            Debug.Print indentChars & "    Value: " & choiceValue.value
            Dim names() As String
            Dim choices() As String
            Call choiceValue.GetChoices(names, choices)
            Debug.Print indentChars & "    Choices:"
            Dim i As Integer
            For i = 0 To UBound(names)
                Debug.Print indentChars & "      " & names(i) & ", " & choices(i)
            Next
        Case kAssetValueTypeColor
            Debug.Print indentChars & "  Type: Color"
            Dim colorValue As ColorAssetValue
            Set colorValue = inValue
            Debug.Print indentChars & "  HasConnectedTexture: " & colorValue.HasConnectedTexture
            Debug.Print indentChars & "  HasMultipleValues: " & colorValue.HasMultipleValues
            If Not colorValue.HasMultipleValues Then
                Debug.Print indentChars & "  Color: " & ColorToString(colorValue.value)
            Else
                Debug.Print indentChars & "  Colors"
                Dim colors() As color
                colors = colorValue.Values
                For i = 0 To UBound(colors)
                    Debug.Print indentChars & "    Color: " & ColorToString(colors(i))
                Next
        Case kAssetValueTypeFilename
            Debug.Print indentChars & "  Type: Filename"
            Dim filenameValue As FilenameAssetValue
            Set filenameValue = inValue
            Debug.Print indentChars & "    Value: " & filenameValue.value
        Case kAssetValueTypeFloat
            Debug.Print indentChars & "  Type: Float"
            Dim floatValue As FloatAssetValue
            Set floatValue = inValue
            Debug.Print indentChars & "    Value: " & floatValue.value
        Case kAssetValueTypeInteger
            Debug.Print indentChars & "  Type: Integer"
            Dim integerValue As IntegerAssetValue
            Set integerValue = inValue
            Debug.Print indentChars & "    Value: " & integerValue.value
        Case kAssetValueTypeReference
            ' This value type is not currently used in any of the assets.
            Debug.Print indentChars & "  Type: Reference"
            Dim refType As ReferenceAssetValue
            Set refType = inValue
        Case kAssetValueTypeString
            Debug.Print indentChars & "  Type: String"
            Dim stringValue As StringAssetValue
            Set stringValue = inValue
            Debug.Print indentChars & "    Value: """ & stringValue.value & """"
    End Select
End Sub
Private Sub PrintAssetValueToFile( _
    ByRef f As Integer, _
    Print #f, indentChars & "Value"
    Print #f, indentChars & "  DisplayName: " & inValue.DisplayName
    Print #f, indentChars & "  Name: " & inValue.Name
    Print #f, indentChars & "  IsReadOnly: " & inValue.IsReadOnly
            Print #f, indentChars & "  Type: Texture"
                    Print #f, indentChars & "  TextureType: kTextureTypeBitmap"
                    Print #f, indentChars & "  TextureType: kTextureTypeChecker"
                    Print #f, indentChars & "  TextureType: kTextureTypeGradient"
                    Print #f, indentChars & "  TextureType: kTextureTypeMarble"
                    Print #f, indentChars & "  TextureType: kTextureTypeNoise"
                    Print #f, indentChars & "  TextureType: kTextureTypeSpeckle"
                    Print #f, indentChars & "  TextureType: kTextureTypeTile"
                    Print #f, indentChars & "  TextureType: kTextureTypeUnknown"
                    Print #f, indentChars & "  TextureType: kTextureTypeWave"
                    Print #f, indentChars & "  TextureType: kTextureTypeWood"
                Case Else
                    Print #f, indentChars & "  TextureType: Unexpected type returned"
            End Select
            Print #f, indentChars & "  Values"
            Next
            Print #f, indentChars & "  Type: Boolean"
            Print #f, indentChars & "    Value: " & booleanValue.value
            Print #f, indentChars & "  Type: Choice"
            Print #f, indentChars & "    Value: " & choiceValue.value
            Print #f, indentChars & "    Choices:"
            Dim i As Integer
                Print #f, indentChars & "      " & names(i) & ", " & choices(i)
            Next
            Print #f, indentChars & "  Type: Color"
            Print #f, indentChars & "  HasConnectedTexture: " & colorValue.HasConnectedTexture
            Print #f, indentChars & "  HasMultipleValues: " & colorValue.HasMultipleValues
                Print #f, indentChars & "  Color: " & ColorToString(colorValue.value)
            Else
                Print #f, indentChars & "  Colors"
                    Print #f, indentChars & "    Color: " & ColorToString(colors(i))
                Next
            Print #f, indentChars & "  Type: Filename"
            Print #f, indentChars & "    Value: " & filenameValue.value
            Print #f, indentChars & "  Type: Float"
            Print #f, indentChars & "    Value: " & floatValue.value
            Print #f, indentChars & "  Type: Integer"
            Print #f, indentChars & "    Value: " & integerValue.value
            Print #f, indentChars & "  Type: Reference"
            Print #f, indentChars & "  Type: String"
            Print #f, indentChars & "    Value: """ & stringValue.value & """"
    End Select
End Sub
 Philippe.
Philippe Leefsma
