Hi all
I have one big problem copy and paste symbols in one idw to another idw it takes to much time.
it's possible through macro or ilogic for copying symbols in drawings?
please help me?
Thanks and regards,
LINUS KOTTE
Solved by jdkriek. Go to Solution.
This will copy all the symbols from a defined drawing into the active drawing:
Public Sub CopySymbols() 'JDK 2013 Dim oApp As Inventor.Application Set oApp = ThisApplication Dim thisIDW As DrawingDocument Set thisIDW = oApp.ActiveDocument 'Define source path of Symbol Drawing Dim pathIDW As String pathIDW = "J:\\Templates\Symbols.idw" Dim sourceIDW As DrawingDocument Set sourceIDW = oApp.Documents.Open(pathIDW, False) Dim symbolDef As SketchedSymbolDefinition 'Copy all the symbols into active drawing For Each symbolDef In sourceIDW.SketchedSymbolDefinitions Call symbolDef.CopyTo(thisIDW, ReplaceExisting:=True) Next End Sub
Here is a similar one that uses a form to select the symbols you want from the source drawing.
Public Sub SymbolCopy() ' These must already be declared ' Dim _invApp As Inventor.Application ' Public Shared inventorDoc As Inventor.Document ' SymbolName is the Name of the Symbol to be copied ' oSourceDwg is the document that the symbol currently resides in. ' oTargetDwg is the document that the symbol is to be placed into. ' Symbols is the name of the Form. The form has an "Insert" and "Cancel", a listbox, and a checkbox. ' ListBox_Resource is a list box on Symbols Form. Set up list box to select multiple items. ' ReplaceExisting is a checkbox on Symbols Form "Replace existing symbol" ' Check to make sure active inventor document is a drawing. If Not inventorDoc.DocumentType = DocumentTypeEnum.kDrawingDocumentObject Then MessageBox.Show("This is not a drawing document...", "Error...", MessageBoxButtons.OK, MessageBoxIcon.Warning) Exit Sub End If ' Set a reference to the drawing document. Dim oTargetDwg As DrawingDocument oTargetDwg = inventorDoc ' Open the source drawing document. This could be converted to a OpenFileDialog. Dim SourceFile As String = "C:\Vault Workspace\CAD Administration\Templates 2013\Symbols\Symbols.dwg" ' Check to see if the file exists. If Not System.IO.File.Exists(SourceFile) Then MessageBox.Show("Download Symbols.dwg from Vault...", "Missing File", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) Exit Sub End If ' Set a reference to the source document. Dim oSourceDwg As DrawingDocument oSourceDwg = _invApp.Documents.Open(SourceFile, False) ' Create the new sketched symbol definition. Dim oSketchedSymbolDef As SketchedSymbolDefinition ' Clear items on form listbox named "ListBox_Resource" Symbols.ListBox_Resource.Items.Clear() ' Add symbol names from source drawing to the list box Dim j As Integer For j = 1 To oSourceDwg.SketchedSymbolDefinitions.Count Dim s As String = oSourceDwg.SketchedSymbolDefinitions.Item(j).Name Symbols.ListBox_Resource.Items.Add(s) Next ' Sort the symbols list box Symbols.ListBox_Resource.Sorted = True ' capture Symbols Dialog results. Dim results As DialogResult = Symbols.ShowDialog() ' Exit sub if dialog is canceled If results = Windows.Forms.DialogResult.Cancel Then ' Close the source drawing oSourceDwg.Close(True) oSourceDwg = Nothing Exit Sub End If ' Define list of symbols to be added to the drawing based on user selection in the list box Dim SymbolNames As List(Of String) = New List(Of String)() For n As Integer = 0 To Symbols.ListBox_Resource.SelectedItems.Count - 1 SymbolNames.Add(Symbols.ListBox_Resource.SelectedItems.Item(n)) Next ' Error check If Not SymbolNames.Count > 0 Then MessageBox.Show("No symbols selected...", "Error...", MessageBoxButtons.OK, MessageBoxIcon.Exclamation) ' Close the source drawing oSourceDwg.Close(True) oSourceDwg = Nothing Exit Sub End If ' Sets to True or False for the ".CopyTo" which will replace an existing symbol if True Dim ReplaceExisting As Boolean = Symbols.CheckBox_ReplaceSymbol.Checked ' Add sketched symbols to the target drawing Dim i As Integer For Each SymbolName As String In SymbolNames For i = 1 To oSourceDwg.SketchedSymbolDefinitions.Count If oSourceDwg.SketchedSymbolDefinitions.Item(i).Name = (SymbolName) Then oSketchedSymbolDef = oSourceDwg.SketchedSymbolDefinitions.Item(i).CopyTo(oTargetDwg, ReplaceExisting) End If Next Next ' Close the source drawing oSourceDwg.Close(True) oSourceDwg = Nothing ' Invoke the drawing symbols command in inventor drawing _invApp.CommandManager.ControlDefinitions("DrawingSymbolsCmd").Execute() End Sub
