Inventor Customization
Active Contributor
tclayton
Message 1 of 5 (281 Views)
Convert model parameter to reference parameter
281 Views, 4 Replies
10-02-2012 07:52 PM
I need to convert a model parameter to a reference parameter thru the API.
I saw this item discussed in the group before, but I cant find the thread.
Can anyone help me out?
Excellent answer, thank you
*Pro
jletcher
Message 2 of 5 (266 Views)
Re: Convert model parameter to reference parameter
10-03-2012 11:37 AM in reply to: tclayton
Property Driven() As VARIANT_BOOL
James Letcher
2012 Factory Design Suite ( will not load 2013)
What happen to my Inventor :-(
Active Contributor
tclayton
Message 3 of 5 (251 Views)
10-04-2012 08:29 PM in reply to: jletcher
Sorry, I didn't get that answer.
Has anyone put the " ModelParameter.Convert to Reference Parameter" Method?
ADN Support Specialist
Vladimir.Ananyev
Message 4 of 5 (226 Views)
10-11-2012 12:16 AM in reply to: tclayton
ConvertToReferenceParameter method works fine but not for built-in model parameters. See help.   If you create model parameter programmatically then you are free to call this method. Try the following VBA sample.
Private Sub Model2Refs_1()
  Dim oDef As PartComponentDefinition
  Set oDef = ThisApplication.ActiveDocument.ComponentDefinition
  Dim oPars As Parameters
  Set oPars = oDef.Parameters
  Dim oModelPars As ModelParameters
  Set oModelPars = oPars.ModelParameters
  Dim oModelPar As ModelParameter
  'create model parameter (not built-in)
  Set oModelPar = oModelPars.AddByExpression("333 mm", "mm", "NonBuiltIn")
  'change its type to reference
  Call oModelPar.ConvertToReferenceParameter
End Sub
You may control Boolean Driven property of dimension constraints. Create new part with the rectangle on the first sketch + create pair of dimensions (so you will get pair of model parameters). The following VBA code convert parameter which controls the first dimension constraint to reference type.
Private Sub Model2Refs_2()
  Dim oDoc As PartDocument
  Set oDoc = ThisApplication.ActiveDocument
  Set oDef = oDoc.ComponentDefinition
  Dim oSketch As PlanarSketch
  Set oSketch = oDef.Sketches.Item(1)
  Dim oDims As DimensionConstraints
  Set oDims = oSketch.DimensionConstraints
  Dim oDim As TwoPointDistanceDimConstraint
  Set oDim = oDims.Item(1)
  oDim.Driven = True
End Sub
Hope the idea is clear.
Cheers,
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
Active Contributor
tclayton
Message 5 of 5 (221 Views)
10-11-2012 06:51 AM in reply to: Vladimir.Ananyev
