Hi all,
I need a macro to convert all the inventor drgs in the specifed folder to pdf files and saved in the same folder.
yes. i know that there is save copy as option to convert each file into pdf one by one. but is it possible to create pdf for all drgs in a single click i.e easy way when compared to the above one.
Hope someone will help...
thanks
Solved by rossano_praderi. Go to Solution.
I'm sure there is code available to do what you want, but you could use Task Scheduler to run a Print Files task to a PDF printer to do this.
with this macro you have to choice a folder and all the idw inside that folder will be saved as pdf (this macro open each file before save them).
Sub FilesToPdf() Dim oDoc As DrawingDocument Dim aPath, FileName As String Dim FSO, FSO_FOLDER, FSO_FILE As Object aPath = SelFolder If aPath <> "" Then Set FSO = CreateObject("Scripting.FileSystemObject") Set FSO_FOLDER = FSO.GetFolder(aPath & "\") If FSO_FOLDER.Files.Count > 0 Then For Each FSO_FILE In FSO_FOLDER.Files If FSO.GetExtensionName(FSO_FILE) = "idw" Then Set oDoc = ThisApplication.Documents.Open(FSO_FILE) Call oDoc.SaveAs(Replace(FSO_FILE, ".idw", ".pdf"), True) oDoc.Close (False) End If Next Else MsgBox "No Files Found at " & aPath End If Set FSO = Nothing Set FSO_FOLDER = Nothing End If End Sub Private Function SelFolder() As String Dim folderDialog As FileDialog Dim ShellApp, result Set ShellApp = CreateObject("Shell.Application").BrowseForFolder(0, "Please choose a folder", 1, _ ThisApplication.FileLocations.Workspace) SelFolder = "" If (ShellApp.items.Item.Path <> "") Then SelFolder = ShellApp.items.Item.Path End If End Function
Bregs
Rossano Praderi
Hi Dshortway,
thanks for spending your valuable time.
this macro gives the right result but output pdf file is not in black color. while converting pdf , we set the property "All color as black" as true. i think this one is missing in the macro. could you please update the macro to get the desired result.
regards
rishbi
You should be able to throw this in up top:
oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism oOptions = ThisApplication.TransientObjects.CreateNameValueMap If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 1 oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintAllSheets 'oOptions.Value("Custom_Begin_Sheet") = 2 'oOptions.Value("Custom_End_Sheet") = 4 End If oDataMedium = ThisApplication.TransientObjects.CreateDataMedium
Make sure you actually want those options.
Then swap your SaveAs for:
oPDFAddIn.SaveCopyAs(oDoc, oContext, oOptions, oDataMedium)
Hi Rishbi,
i would like to give you an other example of code that include the "options" suggested by Wisbell.
Bregs
Rossano Praderi
and ... as your request... this is my updated macro...
Sub FilesToPdf() Dim oDoc As DrawingDocument Dim aPath, FileName As String Dim FSO, FSO_FOLDER, FSO_FILE As Object aPath = SelFolder If aPath <> "" Then Set FSO = CreateObject("Scripting.FileSystemObject") Set FSO_FOLDER = FSO.GetFolder(aPath & "\") If FSO_FOLDER.Files.Count > 0 Then For Each FSO_FILE In FSO_FOLDER.Files If FSO.GetExtensionName(FSO_FILE) = "idw" Then Set oDoc = ThisApplication.Documents.Open(FSO_FILE) Call SaveAsPdf(oDoc, Replace(FSO_FILE, ".idw", ".pdf")) 'Call oDoc.SaveAs(Replace(FSO_FILE, ".idw", ".pdf"), True) oDoc.Close (True) End If Next Else MsgBox "No Files Found at " & aPath End If Set FSO = Nothing Set FSO_FOLDER = Nothing End If End Sub Sub SaveAsPdf(oDocument As Inventor.Document, oFileName As String) Dim oOptions, oContext, oPDFAddIn, NameValueMapoDataMedium, oDataMedium Set oPDFAddIn = ThisApplication.ApplicationAddIns.ItemById("{0AC6FD96-2F4D-42CE-8BE0-8AEA580399E4}") Set oContext = ThisApplication.TransientObjects.CreateTranslationContext oContext.Type = IOMechanismEnum.kFileBrowseIOMechanism Set oOptions = ThisApplication.TransientObjects.CreateNameValueMap Set oDataMedium = ThisApplication.TransientObjects.CreateDataMedium oDataMedium.FileName = oFileName If oPDFAddIn.HasSaveCopyAsOptions(oDataMedium, oContext, oOptions) Then oOptions.Value("All_Color_AS_Black") = 0 ' set to 0 for colors 'oOptions.Value("All_Color_AS_Black") = 1 ' set to 1 for black/white oOptions.Value("Remove_Line_Weights") = 1 oOptions.Value("Vector_Resolution") = 400 oOptions.Value("Sheet_Range") = Inventor.PrintRangeEnum.kPrintSheetRange oOptions.Value("Custom_Begin_Sheet") = 1 oOptions.Value("Custom_End_Sheet") = oDocument.Sheets.Count End If Call oPDFAddIn.SaveCopyAs(oDocument, oContext, oOptions, oDataMedium) 'Publish Document End Sub Private Function SelFolder() As String Dim folderDialog As FileDialog Dim ShellApp, result Set ShellApp = CreateObject("Shell.Application").BrowseForFolder(0, "Please choose a folder", 1, _ ThisApplication.FileLocations.Workspace) SelFolder = "" If (ShellApp.items.Item.Path <> "") Then SelFolder = ShellApp.items.Item.Path End If End Function
Bregs
Rossano Praderi
Dear members
This is exactly what i was looking for!
Thanks to
Mr.Rossano Praderi
Mr.Wisbell
regards
gobi
