Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
controlling when a rule runs
0 REPLIES 0
Message 1 of 1
swordmaster
188 Views, 0 Replies
Looking for some ideas for how to solve this.
I have an assembly driven with ilogic rules. When the assembly is opened in the default level of detail a ilogic error is generated because i have rules changing the state of components (suppressed/unsuppressed). which kind of makes sense since you need a level of detail to suppress/unsuppress.
I say kind of because I have never experienced this problem with other ilogic driven assemblies.
So i was thinking to check what the active level of detail is (i know how to do that) and only run the rules with the suppression code when it is my custom level of detail.
Problem i am having is checking which ilogic level of detail is active AFTER opening the assembly (ie firing that rule)
I do not want to use the "on open document" event.
This does not work well in Inventor/Ilogic 2009
thanks
Inventor 2010 Certified Professional
0 REPLIES 0
