Control visibility of parts in darwing view
6 REPLIES 6
theo.bot
2019 Views, 6 Replies
Dear,
I'm creating a small product configurator usig ilogic. It all works fine, but i've i challange:
controlling the visibility of the components in a drawing view
In simple words, every occourense of my assembly has an custum Ipropertie calles "Positie". there where 4 values (Bodem, Zij, Kop, Deksel and Overig)
In a drawing view i only want to see the parts that has a spesific value of the ipropertie "Positie".
I found a sample code for VBA, but I cann't get it worked in ilogic.:
Sub HideSecond()
'Assumes you have an open drawing
'Assumes that view 1 of the active sheet is an assembly
'Turns off visibility of assembly's second component in open drawing's first view
'Get the drawing document
Dim oDrawingDocument As Inventor.DrawingDocument
Set oDrawingDocument = ThisApplication.ActiveDocument
'Get the first view
Dim oView As Inventor.DrawingView
Set oView = oDrawingDocument.ActiveSheet.DrawingViews.Item(1)
'Get the assembly document referenced by the view
Dim oAssemblyDocument As Inventor.AssemblyDocument
Set oAssemblyDocument = oView.ReferencedDocumentDescriptor.ReferencedDocum​ent
'Get the second component occurrence of the assembly document
Dim oSecondOccurrence As Inventor.ComponentOccurrence
Set oSecondOccurrence = oAssemblyDocument.ComponentDefinition.Occurrences.​Item(2)
'Turn off visibility of the second occurrence
oView.SetVisibility oSecondOccurrence, False
End Sub
Can someone give me a hind to turn this into ilogic and add the option to check the ipropertie to turn on the visibility
Kind regards,
theo Bot
6 REPLIES 6
xiaodong_liang
in reply to: theo.bot
I pasted the VBA code to iLogic. After I modified according to the error messages iLogic provides, the rule works.
'Get the first view
  oAssemblyDocument = oView.ReferencedDocumentDescriptor.ReferencedDocument
  oSecondOccurrence = oAssemblyDocument.ComponentDefinition.Occurrences.Item(2)
oView.SetVisibility (oSecondOccurrence, False)
Best regards,
Xiaodong Liang
Developer Consultant
Autodesk Developer Technical Services
ADNpati
in reply to: xiaodong_liang
Turning off the visibility of Skecthc in Occureneces in Main Assembly":::::::::::
Sub FzAsmOn()
Call SetVisibleOn(False)
End Sub
Private Sub SetVisibleOn(bflag)
Dim oDoc As AssemblyDocument
Set oDoc = ThisApplication.ActiveDocument
Dim oOccDef As Inventor.ComponentDefinition
Set oOccDef = oDoc.ComponentDefinition
Dim oAsmDoc As Document
Dim oOcc As ComponentOccurrence
Dim oSks As PlanarSketches
Dim oSketch As PlanarSketch
For i = 1 To oDoc.ComponentDefinition.occurrences.Count
If oDoc.ComponentDefinition.occurrences(i).Definition.Type = kAssemblyComponentDefinitionObject Then
Set oAsmDoc = oDoc.ComponentDefinition.occurrences(i).Definition.Document
Set oSks = oAsmDoc.ComponentDefinition.Sketches
End If
For Each oSketch In oSks
oSketch.visible =  Flase
Next
Next
'oDoc.Update
End Sub
Can you please check the code and please let me know themodifications
Because Sktches are not turning off...
Please hve a look. and make coode to turn the sketches off.
Thanks.
Mechanical Engineer
Inventor Applications Engineer
If my solution seems to remedy your problem, please press the Accept Solution button, Some KUDOS -
xiaodong_liang
The code looks fine to me. Did you meet any problem? Note: In default, a new assembly has not any sketches until you add it.
ADNpati
Hello Xiaodong Liang,
Morning,
If there are any sketches in assembly, which is(assembly) as occurrence in the main assembly, those sketches are not turnign off and on.
Please find the attachment JPG file, Ithis is a ssample asssembly. I am writing for a machice assembly having thousands of occurrences.
In Assembly2:1, I wolud like to toggle sketch "Sketch 1" on and off as well as "Sketch 2" in Assembly4:1.
Code is runnig but the sketches are turning off and on.
Is there any other way to do it??? Is it possibe??
Let me know your openion.
Thenaks.
Mechanical Engineer
Vladimir.Ananyev
in reply to: ADNpati
Sketches from subassemblies are represented in the parent assembly context by their proxy objects.
That is why we should use a bit more complex procedure:
1) get the reference to the sketch in subassembly context
2) create sketch proxy object for this sketch in the context of parent assembly
3) change visibility of this proxy object.
The following VBA sample illustrates this idea.
It toggles the visibility of planar sketches in all subassemblies on the first hierarchy level.
Private Sub Test_SubAssemblySketches()
  Dim oAssyDoc As AssemblyDocument
  Set oAssyDoc = ThisApplication.ActiveDocument
  Dim oAssyDef As AssemblyComponentDefinition
  Set oAssyDef = oAssyDoc.ComponentDefinition
  'toggle visibility of sketches in the main assembly
  Dim oSk As Sketch
  For Each oSk In oAssyDef.Sketches
    oSk.Visible = Not oSk.Visible
  Next
  'process all subassemblies
  For Each oOcc In oAssyDef.Occurrences
    If oOcc.Definition.Type = kAssemblyComponentDefinitionObject Then
      Dim oDef As AssemblyComponentDefinition
      Set oDef = oOcc.Definition
      'toggle visibility of sketches in subassemblies
      Dim oSkProxy As PlanarSketchProxy
      For Each oSk In oDef.Sketches
        Call oOcc.CreateGeometryProxy(oSk, oSkProxy)
        oSkProxy.Visible = Not oSkProxy.Visible
      Next
    End If
  Next 'oOcc
End Sub
For multi-level main assembly you should implement recursive assembly structure traversal.
You may find an article “Working with proxies through the API” in the Inventor API Help.
Best regards,
Vladimir Ananyev
Autodesk Developer Network
ADNpati
in reply to: Vladimir.Ananyev
Perfecto !!!!!!
Mechanical Engineer
