Why can't Autodesk be more consistent?
I'm trying to use Part Number in my Description Field in Family Table.
I.e.. Hex head bolt : DIN 931-1 - M6 x 60
Countersunk bolt : M4 x 20 DIN 7991
Why the switch???
It's true there is a lot of inconsistancy in Content Center, must have been a lot of different teams building these tables.
You can edit the way these columns are put together, by right clicking the column header and choosing Column Properties. Rearrange the Expression Column until you get the Part Number to appear however you want, then map to Description property.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
