I have some parts in a subassembly that I want to make invisible. When I input my iLogic code(that I used hundreds of times before) the part is made invisible in the subassembly only if I open the subassembly. When I go back to the parent assembly it still shows the part visible. Here is a sample of my code:
If ACCESS_DOOR = "NO DOOR" Then Component.InventorComponent("INSPECTION DOOR:1").BOMStructure=BOMStructureEnum.kReferenceBOMStructure Component.Visible("INSPECTION DOOR:1") = False Else If ACCESS_DOOR = "12X12X6" Then Component.InventorComponent("INSPECTION DOOR:1").BOMStructure=BOMStructureEnum.kDefaultBOMStructure Component.Visible("INSPECTION DOOR:1") = True Parameter("ACCESS DOOR GASKET:1", "HORIZ_DOOR_SIZE") = 12 Parameter("ACCESS DOOR:1", "HORIZ_DOOR_SIZE") = 12 Parameter("ACCESS DOOR BACK PLT:1", "HORIZ_DOOR_SIZE") = 12 Parameter("ACCESS DOOR GASKET:1", "HORIZ_DOOR_SIZE2") = 6 Parameter("ACCESS DOOR:1", "HORIZ_DOOR_SIZE2") = 6 Parameter("ACCESS DOOR BACK PLT:1", "HORIZ_DOOR_SIZE2") = 6 Parameter("ACCESS DOOR GASKET:1", "VERT_DOOR_SIZE") = 12 Parameter("ACCESS DOOR:1", "VERT_DOOR_SIZE") = 12 Parameter("ACCESS DOOR BACK PLT:1", "VERT_DOOR_SIZE") = 12 Component.Visible("ACCESS DOOR STUD:2")= False Component.Visible("ACCESS DOOR CLAMP:2") = False Component.Visible("ACCESS DOOR HANDLE:2") = False Component.Visible("ACCESS DOOR STUD:8") = False Component.Visible("ACCESS DOOR CLAMP:8") = False Component.Visible("ACCESS DOOR HANDLE:8") = False Parameter("ACCESS DOOR:1", "SIDE_CLAMP_OFFSET") = "5.625" Parameter("ACCESS DOOR:1", "LOWER_CLAMP_OFFSET") = "1.5" Parameter("ACCESS DOOR:1", "UPPER_CLAMP_OFFSET") = "3" Else If ACCESS_DOOR = "16X16X9" Then Component.InventorComponent("INSPECTION DOOR:1").BOMStructure=BOMStructureEnum.kDefaultBOMStructure Component.Visible("INSPECTION DOOR:1") = True Parameter("ACCESS DOOR GASKET:1", "HORIZ_DOOR_SIZE") = 16 Parameter("ACCESS DOOR:1", "HORIZ_DOOR_SIZE") = 16 Parameter("ACCESS DOOR BACK PLT:1", "HORIZ_DOOR_SIZE") = 16 Parameter("ACCESS DOOR GASKET:1", "HORIZ_DOOR_SIZE2") = 9 Parameter("ACCESS DOOR:1", "HORIZ_DOOR_SIZE2") = 9 Parameter("ACCESS DOOR BACK PLT:1", "HORIZ_DOOR_SIZE2") = 9 Parameter("ACCESS DOOR GASKET:1", "VERT_DOOR_SIZE") = 16 Parameter("ACCESS DOOR:1", "VERT_DOOR_SIZE") = 16 Parameter("ACCESS DOOR BACK PLT:1", "VERT_DOOR_SIZE") = 16 Component.Visible("ACCESS DOOR STUD:2") = True Component.Visible("ACCESS DOOR CLAMP:2") = True Component.Visible("ACCESS DOOR HANDLE:2") = True Component.Visible("ACCESS DOOR STUD:8") = True Component.Visible("ACCESS DOOR CLAMP:8") = True Component.Visible("ACCESS DOOR HANDLE:8") = True Parameter("ACCESS DOOR:1", "SIDE_CLAMP_OFFSET") = "7" Parameter("ACCESS DOOR:1", "LOWER_CLAMP_OFFSET") = "3" Parameter("ACCESS DOOR:1", "UPPER_CLAMP_OFFSET") = "6" End If
The components I'm referring to are the components "Component.Visible("ACCESS DOOR STUD:2") = True" for the stud,clamp, and handle. Any help with this will be much appreciated. It's driving me a little crazy.
