To clarify: I have a component pattern that I need to change one part of it to a different part.
For reference, I have a model that is run by an excel spreadsheet for input/output. If a certain option is selected on the input, I need inventor to either replace component or not. So, using the picture, let's say I need to replace the component 'CM51 90 PROFILE LH:10' only at position 10 with a different ipt. When I originally tried this in iLogic, it replaced all the parts instead of just the one instance of the part.
Is it possible for Excel to drive the iLogic function for a single ipt instance in a pattern?
