Hello to all-
I'm trying to do some bulk creations with .ipts publishing them out as .dwf's. I currently have my code set up to pull from the network but I've noticed a significant performance increase if I run my code from my local computer. But, I've already created my dwgs and they are pulling from a master .ipt on the network. What I would like to do is simply change the location of that file, not the file its self.
The following example is a file location for a spacer dwg file and I want to change the pulling location from the network to the computer.
(Network) Q\CAD\Development\Master_RD_Spacer.ipt
(Local) C:\CAD\Development\Master_RD_Spacer.ipt
As you can see they're the exact same file just in different locations.
Can this be done? Do I have investigate component definitions?
Please HELP!!!
