im looking for a way to suppress or delete a Component part feature from the assembly level by giving component name ("Part1") and component Feature name ("Hole6") thru the API
Thanks in advance......
Solved by montylowe. Go to Solution.
I figured it out.
My Code
if component is not suppressed then it goes out and suppresses or unsuppresses the feature based on a switch you send it.
Sub
oCompDef = oDoc.ComponentDefinition
oCompOcc = oCompDef.Occurrences.ItemByName(Comp)
ofeat = iFeature.InventorFeature(Comp, Feat)
Sub ACSFeat(ByVal Comp, ByVal Feat, ByVal SWT)
Dim oCompDef As Inventor.ComponentDefinition
Dim oCompOcc As Inventor.ComponentOccurrence
Dim ofeat As PartFeature
If oCompOcc.Suppressed = False Then
If SWT = False Then
If ofeat.Suppressed = False Then
Else
End If
Else
If ofeat.Suppressed = True Then
Else
End If
End If
Else
End If
End Sub
