The properties you are referring to Ole are the display properties of the
box.
In the code environment you need to type
combobox1.list
Not all properties are listed in the properties box...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
http://www.sdotson.com/faq.html
"Ole Germer"
wrote in message
news:6AEE84EE77BFABECFA518A9D58F69EB0@in.WebX.maYIadrTaRb...
> Are you sure about hitting F1? After all that is help!!
> Inside properties there is no List Properties . If I use Alphabetic
setting
> in the properties -ComboBox1 there is a Left, ListRows, ListStyle,
> ListWidth and then Locked. That is all the L s.
> Ole
> "Kent Keller" wrote in message
> news:FD3BBF5514AA2C8433A87FAABFCBED2F@in.WebX.maYIadrTaRb...
> > Ole
> > I just placed a combo box, and highlighted it, then hit F1, and went to
> Properties.
> > Inside of Properties is "List Property" which says it Returns or sets
the
> list entries of
> > a ListBox or ComboBox
> > Is that not what you want?
> > Kent
> > Member of the Autodesk Discussion Forum Moderator Program
> > "Ole Germer" wrote in message
> > news:195FF44FF4B10272142D475FBFD49AC6@in.WebX.maYIadrTaRb...
> > > In Visual Basic there is a "List" in the properties. Not in VBA for
> > > Inventor. How do you do your list without it?
> > > Ole
