Is it possible to make the column 'REV' automatically equal to the 'Item' column in attached BOM view? I manually added the values 1 to 5 in the REV column for example.
Maybe with some help of an ilogic rule? I don't know if it's possible and/or where to start.
When i place a mono-part-detail on a assembly drawing i want to be able to place a leader referenced to the REV value. When this is possible there is a link between assembly item nr and the mono-part leader.
Gr. Nick
Please copy this iLogic rule to assembly document.
It makes revision number equal to item number in each BOM row
(for normal parts and virtual components).
' Makes Revision Number equal to ItemNumber in every BOM row Dim oBOM As BOM = ThisDoc.Document.ComponentDefinition.BOM 'enable BOM view "Structured" oBOM.StructuredViewEnabled = True 'reference to BOM view "Structured" Dim oBOMView As BOMView = oBOM.BOMViews.Item(2) For Each oBomRow As BOMRow In oBOMView.BOMRows Dim oDef As ComponentDefinition _ = oBomRow.ComponentDefinitions.Item(1) Dim oProps As Inventor.PropertySet If oDef.Type = ObjectTypeEnum.kVirtualComponentDefinitionObject Then oProps = oDef.PropertySets.Item("Summary Information") Else oProps = oDef.Document.PropertySets.Item("Summary Information") End If 'set new Revision number value equal to ItemNumber Dim oProp As Inventor.Property oProp = oProps.Item("Revision Number") oProp.Value = oBomRow.ItemNumber Next
