What is the iLogic code (or VB.NET code) I could use within a rule to get the Windows user login name? Similar to AutoLISP's (getvar "LOGINNAME").
Thx!
Solved by jlane. Go to Solution.
Solved by NachitoMax. Go to Solution.
Solved by ekinsb. Go to Solution.
.Net supports getting the username but it's probably easier to just use Inventor's API. This will get it:
ThisApplication.UserName
Nacho
Automation & Design Engineer
Inventor Programmer (C#, VB.Net / iLogic)
