Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Close iLogic Form
4 REPLIES 4
ccoomes
1363 Views, 4 Replies
Close iLogic Form
Sorry if this has been answered, but I cannot find the topic.
Could someone please tell me how can I close an iLogic Form from either an iLogic Rule, or a VBA Rule?
Can you please give me the full code text required to close a form called "Mr Form" it would be greatly apprecitated.
Many Thanks.
4 REPLIES 4
skyngu
in reply to: ccoomes
one question, how can you open ilogic form?
Autodesk Inventor Professional 2019
ccoomes
in reply to: skyngu
I have managed to do it, but I use a piece of Macro Code (I found on this forum, but I cannot remember the authors name, sorry) that runs an external iLogic Rule from VBA that opens the from through another iLogic Rule.
It works quite well as I could not figure out how to open the forms through VBA either.
You can either run the VBA code from a Button on the Ribbon / Quick Access or you can create an iLogic Rule that runs the VBA Code that inturn runs the External iLogic Rule.
No doubt there is a much simpler way to open a Form from VBA code, but this works for me.
I can post the VBA code if you would like me too?
I still need to find the code to Close an iLogic Form from VBA though...
MegaJerk
in reply to: skyngu
The iLogic code to show a form (Inventor 2012 and up) is simply
iLogicForm.Show("Form 1")
Where "Form 1" is the name of your form.
If my solution worked or helped you out, please don't forget to hit the kudos button 🙂
iLogicCode Injector: goo.gl/uTT1IB
GitHub
Vladimir.Ananyev
In this version there is no API call to close form.
Sorry Smiley Sad
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
