Hi !
I am working on a drawing that uses 4 different dimension styles :
- Metric
- Imperial decimal
- Fractional 1/32
- Fractional 1/64
I would like to have, using a local form, the possibility to change all the dimensions of an existing drawing or set up the dimension style of a new drawing before we start to dimension it.
I am looking into an ilogic rule to set up the local form but I am stuck.
Do you have any idea of how I should create this ilogic rule?
Solved by Ktomberlin. Go to Solution.
You could modify the text in this post. To give you what your looking for. Just update it to your dimension styles names. I would just modify the second rule to be called from your form for each case.
