Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Choose dimension style and converting all dimensions of a drawing using ilogic
1 REPLY 1
coroller.damien
712 Views, 1 Reply
Hi !
I am working on a drawing that uses 4 different dimension styles :
- Metric
- Imperial decimal
- Fractional 1/32
- Fractional 1/64
I would like to have, using a local form, the possibility to change all the dimensions of an existing drawing or set up the dimension style of a new drawing before we start to dimension it.
I am looking into an ilogic rule to set up the local form but I am stuck.
Do you have any idea of how I should create this ilogic rule?
1 REPLY 1
You could modify the text in this post. To give you what your looking for.  Just update it to your dimension styles names.  I would just modify the second rule to be called from your form for each case.
