I have a program that saves the part to the disk. On my PC, the process
inclused checking out the part. On other user's machines, this does not
happen. The only difference between the two is mine has native VB6
installed on it - which I hope is irrelevant since I am doing everything in
VBA for Inventor 7.
Is there some setting that is not setup properly on the other PCs? Or is
there something I need to add to my code? What is happening is that if the
part cannot be checked out, the user has to exit Inventor and reload it
everytime a new part number is pulled. In other words, even manually
checking out the part does not work!
Any help that can be provided with this problem is greatly appreciated!
Private Sub SavePartToDisk()
' Get Workgroup path
' Dim CPX As String - Make Public
Dim len2 As Long
Dim len3 As Long
Dim JobPath As String
Dim chx As String
Dim chx2 As Integer
Dim csx As Integer
len2 = Len(CPX) ' Length of FileLocationsFile
Debug.Print len2
For C = len2 To 1 Step -1 ' Evaluate string characters backwards
chx = Mid(CPX, C, 1) ' Character
Debug.Print ch
If chx = "\" Then
csx = C + 1 ' determine starting character after '\'
chx2 = chx2 + 1
If chx = "\" And chx2 >= 2 Then
Debug.Print chx & "!"
Exit For
End If
End If
Next C
JobPath = Left(CPX, (csx - 1)) & "Parts\"
Debug.Print JobPath
' Save Part to disk
' Dim oPartDoc2 As Inventor.Document - Make Public
If ThisApplication.ActiveDocumentType = kPartDocumentObject Then
Set oPartDoc2 = ThisApplication.ActiveDocument
ElseIf ThisApplication.ActiveDocumentType = kAssemblyDocumentObject Then
Set oPartDoc2 = ThisApplication.ActiveEditObject
len3 = Len(oPartDoc2.FullFileName)
Debug.Print len3
Debug.Print oPartDoc2.FullFileName
Debug.Print Right(Left(oPartDoc2.FullFileName, (len3 - 5)), 4)
End If
' Must define if in edit mode!
Dim X As String
X = oPartDoc2.DocumentType
Debug.Print X
If X <> "12290" Then
MsgBox "A Component Must be Created or Edited before a New Part
No can be Assigned."
Exit Sub
End If
End If
If oPartDoc2.FullFileName = "" Then
Call oPartDoc2.SaveAs(JobPath & PN & ".ipt", False)
Else
Dim ans As Integer
ans = MsgBox("The Current File will be Lost if not Saved,
Continue? ", vbYesNo)
If ans = 6 Then
ElseIf ans = 7 Then
EP = 0 ' Do not Append PN, Update Properties or Get Next BN
End If
End If
ans = MsgBox("The Current File will be Replaced if not Saved,
If ans = 6 Then
MsgBox "The Part has been changed - the new Part Number is: " &
PN & ". An Update will show the effected change."
ElseIf ans = 7 Then
End If
End If
End Sub
