Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
check if it is derived part in vba
1 REPLY 1
skyngu
898 Views, 1 Reply
hi,
how to check if a part document is a derived part in vba? then, I can check if its link is fine and updated.
thanks.
Autodesk Inventor Professional 2019
1 REPLY 1
humbertogo
in reply to: skyngu
from Manufacturing DevBlog
  Public Sub ModifDerivedParams()
        If ThisApplication.ActiveDocument.DocumentType <>
           kPartDocumentObject Then
            MsgBox("Make a Part Document the active document")
            End
        End If
        Dim oDerPart As PartDocument
        oDerPart = ThisApplication.ActiveDocument
        Dim oDerPartComp As DerivedPartComponent
        If oDerPart.ComponentDefinition.ReferenceComponents.
           DerivedPartComponents.Count < 1 Then
            MsgBox("No Derived Part Components in this part")
            End
        End If
        oDerPartComp =
          ReferenceComponents.DerivedPartComponents(1)
        Dim oDerivedPartDef As DerivedPartUniformScaleDef
        oDerivedPartDef = oDerPartComp.Definition
        Dim oDerEntity As DerivedPartEntity
        For Each oDerEntity In oDerivedPartDef.Parameters
            If (oDerEntity.ReferencedEntity.Name = "d1") Then
                oDerEntity.IncludeEntity = True
                Exit For
            End If
        Next
        'Set Definition back, so DerivedPart Document is updated
        oDerPartComp.Definition = oDerivedPartDef
    End Sub
