Inventor Customization
bretrick30
Message 1 of 1 (265 Views)
Check Drawing View Type with iLogic
265 Views, 0 Replies
09-28-2012 01:17 PM
I am trying to create a rule that will loop through all the sheets and the drawing views on those sheets then if the view is not a standard view I want it to do something.  I cant seem to get the code right for accessign the View Type.  Here is what I have that is not working...
oSheets = ThisDoc.Document.Sheets
Dim oViewType As DrawingViewTypeEnum =  oSheets.Item(SheetNumber).DrawingViews.Item(ViewNumber).ViewType
If oViewType <> kStandardDrawingViewType Then
more code here...
End If
Also, is there a way to change the Format of Text for the Section and Detail view call out on the parent view using ilogic?  So instead of just showing the View Name, add some more text to it.
