So the thing is, i have an assembly inside another assembly and between them i have a flush constraint of 0 distance (between XY planes), but i will need to change it if it happens a different situation. Whats the code in vba to change a flush constrain beetween two planes?
Best regards Ari Cardoso.
To achieve the same result, could you set the distance between the planes as a parameter and change the parameter programmatically? That would be a fairly short bit of iLogic code
