Change value of textbox
5 REPLIES 5
423 Views, 5 Replies
how do i change the value of a sketched symbol containing a textbox with text?
I cant find anything that works.
I insert a textbox called "TheName" and in "TheName" there is a textbox with text i want to change.
I know how to get the sketched symol into the drawing but not how to set the text of the textbox
5 REPLIES 5
RodrigoEiras
This piece of code would allow you to go throught the symbols definition in your drawing, locate one of them and access the text boxes on it.
I hope this is what you were asking for.
SyntaxEditor Code Snippet
Dim oDrawingDoc=ThisDrawing.Document
Dim oSketchedSymbolDef    As SketchedSymbolDefinition
Dim oSketch As Sketch
For Each oSketchedSymbolDef In oDrawingDoc.SketchedSymbolDefinitions
    MessageBox.Show("Symbol Name=" & oSketchedSymbolDef.Name , "Debugging")
    If oSketchedSymbolDef.Name="TestSymbol" Then
        oSketchedSymbolDef.Edit(oSketch)
        For Each oTextBox In oSketch.TextBoxes
            MessageBox.Show("Test Box Text=" & oTextBox.Text , "Debugging")
        Next
        oSketchedSymbolDef.ExitEdit(True)
    Else
     'Do nothing
    End If
Next
in reply to: RodrigoEiras
Yes exactly! Thank you!
How do i access dimensions  (d1, d2 and so on...)  in that sketched symbol?
RodrigoEiras
Hi Johan,
You can go through the dimensions in the sketch with a loop like this one:
Be careful!. Values for parameters must be informed in Inventor internal units (cm for distances and radians for angles)
Dim oDimConstraint As DimensionConstraint
'Look for text boxes
Next
'Look for dimensions
For Each oDimConstraint In oSketch.DimensionConstraints
paramX = oDimConstraint.Parameter
Select Case paramX.Name
Case "d1"
paramX.Value = 'new value
Case "d2"
Case "d3"
Case Else
End Select
Next
Else
'Do nothing
End If
Next
Yess! Thank you, my life just got a little bit better!
