I am trying to change the title block of the active sheet using visual basic. I realize this can be done using a snippet in iLogic, but I am creating an external .dll file using Visual Studio.
I have tried...
ThisDoc.Document.ActiveSheet.TitleBlock.Definition = "Title Block Name"
ThisDoc.Document.ActiveSheet.TitleBlock.Definition.Name = "Title Block Name" (This changes the name of the title block in the browser but doesnt swap it out.)
Call ThisDoc.Document.ActiveSheet.TitleBlock.Definition("Title Block Name")
Solved by saseendrankombath. Go to Solution.
This is from the Programming Help file in Inventor. I'm sure you can modify it to suit your needs. It's VBA, but there's just a few tweaks to make it VB.
Public Sub InsertTitleBlockOnSheet() ' Set a reference to the drawing document. ' This assumes a drawing document is active. Dim oDrawDoc As DrawingDocument Set oDrawDoc = ThisApplication.ActiveDocument ' Obtain a reference to the desired border defintion. Dim oTitleBlockDef As TitleBlockDefinition Set oTitleBlockDef = oDrawDoc.TitleBlockDefinitions.Item("Sample Title Block") Dim oSheet As Sheet Set oSheet = oDrawDoc.ActiveSheet ' Check to see if the sheet already has a title block and delete it if it does. If Not oSheet.TitleBlock Is Nothing Then oSheet.TitleBlock.Delete End If ' This title block definition contains one prompted string input. An array ' must be input that contains the strings for the prompted strings. Dim sPromptStrings(1 To 2) As String sPromptStrings(1) = "String 1" sPromptStrings(2) = "String 2" ' Add an instance of the title block definition to the sheet. Dim oTitleBlock As TitleBlock Set oTitleBlock = oSheet.AddTitleBlock(oTitleBlockDef, , sPromptStrings) End Sub
Private Sub OButtonDefA1_OnExecute(ByVal Context As Inventor.NameValueMap) Handles OButtonDefA1.OnExecute On Error Resume Next Dim oDoc As Inventor.DrawingDocument oDoc = m_inventorApplication.ActiveDocument Dim sName As String If oDoc.Sheets.Count = 1 Then If Not Left(oDoc.ActiveSheet.Name, 5) = "00_00" Then sName = "00_00" Call oDoc.Sheets.Add(Inventor.DrawingSheetSizeEnum.kCustomDrawingSheetSize, Inventor.PageOrientationTypeEnum.kLandscapePageOrientation, sName, 80.5, 58.2) oDoc.Sheets.Item(1).Delete(False) Else sName = "01_00" Call oDoc.Sheets.Add(Inventor.DrawingSheetSizeEnum.kCustomDrawingSheetSize, Inventor.PageOrientationTypeEnum.kLandscapePageOrientation, sName, 80.5, 58.2) End If ElseIf oDoc.Sheets.Count > 1 Then sName = Format(oDoc.Sheets.Count, "0#") & "_00" Call oDoc.Sheets.Add(Inventor.DrawingSheetSizeEnum.kCustomDrawingSheetSize, Inventor.PageOrientationTypeEnum.kLandscapePageOrientation, sName, 80.5, 58.2) End If Dim oBorder As Inventor.BorderDefinition oBorder = oDoc.BorderDefinitions.Item("IP-A1") Call oDoc.ActiveSheet.AddBorder(oBorder) Dim oTitle As Inventor.TitleBlockDefinition oTitle = oDoc.TitleBlockDefinitions.Item("IP-TITLE-B") Dim sPromptStrings(1) As String sPromptStrings(0) = "N.T.S" sPromptStrings(1) = "01" Dim oSheet As Inventor.Sheet oSheet = oDoc.ActiveSheet If Not oSheet.TitleBlock Is Nothing Then oSheet.TitleBlock.Delete() End If Dim oTitleBlock As Inventor.TitleBlock oTitleBlock = oSheet.AddTitleBlock(oTitle, , sPromptStrings) End Sub
Hope this will help you
