How can we change(open) the Project file(ipj) with inventor api using vb.net code?
The following is right out of the API Help. The code assumes that the project is already in the lsit of available projects. If it is not then you will need to add it with the DesignProjects.AddExisting() method.
Public Sub SetActiveProject() ' Check to make sure a document isn't open. If ThisApplication.Documents.Count > 0 Then MsgBox "All documents must be closed before changing the project." Exit Sub End If ' Set a reference to the DesignProjectManager object. Dim oDesignProjectMgr As DesignProjectManager Set oDesignProjectMgr = ThisApplication.DesignProjectManager ' Show the current project. Debug.Print "Old active project: " & oDesignProjectMgr.ActiveDesignProject.FullFileName ' Get the project to activate ' This assumes that "C:\Temp\MyProject.ipj" exists. Dim oProject As DesignProject Set oProject = oDesignProjectMgr.DesignProjects.ItemByName("C:\temp\MyProject.ipj") ' Activate the project oProject.Activate ' Show the current project after making the project change. Debug.Print "New active project: " & oDesignProjectMgr.ActiveDesignProject.FullFileName End Sub
This may be a shot in the dark but you know more about code than me!
Would it be possible to open a named version of inventor with a named project file outside of inventor in the windows environments?
Regards
Warren.
