I need help with the .ipt file settings.
When I create a new sketch and I click finish it, Inventor rolls the view.
I want to have the same "view position" (when I click finish the sketch) which I have when I'm drawing the sketch.
When I click finish the sketch, I always get the "start view" (It's when you click on the house right in Inventor).
Hi Michael,
Sorry I do not find a setting that controls that. One suggestion would be to watch for "UserInputEvents.OnTerminateCommand" fired when the sketch is closed, then set up the camera yourself based on the sketch properties. You may not be able to prevent the view from switching back to home view in between however...
I hope it helps.
Philippe.
Philippe Leefsma
Developer Consultant
Developer Technical Services
Global Subscription & Support
Autodesk EMEA
