Inventor Customization
Active Contributor
huanggy
Message 1 of 7 (249 Views)
Change the diameter dimension location
249 Views, 6 Replies
12-23-2012 07:45 PM
Dear All,
We need re-location the diameter dimension after we change the drawing view's scale. but we didn't know how to chane the Startpoint of the dimension (mark with Red word "1"), just find the text location.
Who knows how to set the new point to for the startpoint?
Many appreciate fo any input!
Thanks and My Regards,
Gengyun
ADN Support Specialist
philippe.leefsma
Message 2 of 7 (219 Views)
Re: Change the diameter dimension location
01-10-2013 10:28 PM in reply to: huanggy
Hi Gengyun,
I was trying to modify the "DrawingDimension.DimensionLine" property or start/end point of it but none of this was working, so unfortunately I'm sceptical it is possible to achieve what you are looking for from the API.
I'm sending a query to the devlopment team and will let you know the feedback.
Thank you,
Philippe.
Philippe Leefsma
Developer Technical Services
Autodesk Developer Network
Active Contributor
huanggy
Message 3 of 7 (213 Views)
01-10-2013 10:50 PM in reply to: philippe.leefsma
Thanks, Philippe.
We are ADN member and I forget to log it on Autodesk subscription support.
Looking forward your reply about this case.
My Best Regards,
Gengyun
philippe.leefsma
Message 4 of 7 (207 Views)
01-11-2013 02:05 AM in reply to: huanggy
Hi Gengyun,
Here is the feedback I received:
Currently from API what we can move is the DimensionText.Origin which will move both the point “1” and dimension text (marked as “2” ), but unfortunately there is no API to return the position of the point “1” so we can’t get the distance between the point “1” and the dimension text origin and so we can’t workaround it.
Sorry for the bad news.
Philippe.
Philippe Leefsma
Active Contributor
huanggy
Message 5 of 7 (195 Views)
01-11-2013 06:06 AM in reply to: philippe.leefsma
Thanks for you quicly feedback, Philippe.
The problem is DimensionText.Origin is un-controlable. you may test it by VBA. for example, add 10 for Y, and apply, then add 10 for X and apply. sometimes the text move to wrong direction.
Thanks again and hope Autodesk will fix it in next version.
My Best Regards,
Gengyun
Vladimir.Ananyev
Message 6 of 7 (192 Views)
01-11-2013 07:32 AM in reply to: huanggy
Try this method. It works for me.
Public Sub Test_MoveDimTextBox()
  ' Set a reference to the drawing document.
  ' This assumes a drawing document is active.
  Dim oDrawDoc As DrawingDocument
  Set oDrawDoc = ThisApplication.ActiveDocument
  ' Set a reference to the active sheet.
  Dim oSheet As Sheet
  Set oSheet = oDrawDoc.ActiveSheet
  Dim oView As DrawingView
  Set oView = oSheet.DrawingViews.Item(1)
  Dim oDim As DrawingDimension
  Set oDim = oSheet.DrawingDimensions.Item(1)
  Dim oText As DimensionText
  Set oText = oDim.Text
  ' Change the position of the Dimension Text
  Dim oP As Point2d
  Set oP = oText.Origin
  oP.X = oP.X - 5
  oP.Y = oP.Y + 2
  oText.Origin = oP
  oSheet.Update
  Beep
End Sub
Vladimir Ananyev
Active Contributor
huanggy
Message 7 of 7 (176 Views)
01-14-2013 09:47 PM in reply to: Vladimir.Ananyev
Thanks,Vladimir. we will take a try!
