Inventor Customization
jdkriek
Message 11 of 13 (168 Views)
Re: Change reference .ipt from .idw
07-26-2012 04:47 AM in reply to: jis.augustin
jis.augustin, you are responding to a question that is 7 years old.
Jonathan D. Kriek
Autodesk Inventor Certified Expert
Microsoft Certified Application Developer
_____________________________________________________
Did I help you? Please choose Accept as Solution or Kudos below
Member
jis.augustin
Message 12 of 13 (157 Views)
07-26-2012 05:15 PM in reply to: jdkriek
do you have a better solution by any chance?
Valued Contributor
andrewwhiteinc
Message 13 of 13 (142 Views)
07-27-2012 07:34 AM in reply to: jis.augustin
The command you are looking for I believe is:
dim oDoc as DrawingDocument
Set oDoc = ThisApplication.ActiveDocument 'provided your active document is an .idw
Call oDoc.Sheets(1).DrawingViews(1).ReferencedDocumentDescriptor.ReferencedFileDescriptor.ReplaceReference("C:\Path\Part.ipt") 'set the sheet number to the page and the drawing view number to the base view (typically 1)
P. Andrew White, P.Eng
Manufacturing Engineering Manager
Silent-Aire Manufacturing
