Change PL Header on Drawing Via iLogic?
2 REPLIES 2
obourne
439 Views, 2 Replies
I want to be able to change the header on a PL in a drawing using iLogic.
I'm able to "find" the PL(s) on a drawing but can't seem to figure out how to access the header propoertyy My goal to to change the header to show the P/N of the assembly/part it's created from.
My Current code is below:
doc=ThisDrawing.Document
oBOMs=doc.DrawingBOMs
For Each oBOM In oBOMs
MessageBox.Show("Found a PL", "Title")
Next oBom
In between the for/next loop is where I want to access the current BOM and change it's header depending on the related .iam/.ipt.
Any ideas?
2 REPLIES 2
Curtis_Waguespack
in reply to: obourne
Hi obourne,
Here is a quick example.
I hope this helps.
Curtis
oDocument = ThisDoc.Document
Try
	'look for the first parts list on the drawing
	Dim oPartsList As PartsList
	oPartsList = oDocument.ActiveSheet.PartsLists.Item(1)
	oPartsList.Title = "Hello World"
Catch
	'inform user no parts list was found
	MessageBox.Show("Parts List Not Found", "iLogic")
End Try
Hello Curtis,
I am looking to use your code.
I also have additional parts Lists (tabulation) on the same drawing.
I would place the first part and attach the PL, then place another PL via the "browse" button.
How would I use this code to replace the PL title on a new PL, whenever a new PL is placed from browse?
I greatly appreciate any help you could provide.
Len
Senior Designer/Cad Administrator
Inventor 2012, w/SP2
Vault Collaboration 2012
Dell Precision T3500, Intel Xeon CPU
W3680 @3.33GHz, 16.0 GB of RAM
Microsoft Windows 7 Pro, 64 Bit Edition
Version 2009, w/SP1
