Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Change part's color override VBA code
1 REPLY 1
1364 Views, 1 Reply
How can i change a part's color override through VBA code?
1 REPLY 1
ruthsteed
That depends on what you mean.  Do you mean you want to change the part color in the part itself or in the context of an assembly?  This sub will set the part color if the active document is a part, or the first occurrence's color if the active document is an assembly. It assumes that the "Gold" color style is not already in your document.
Sub PartColor()
    Dim oAsset As Asset
    Dim oLib As AssetLibrary: Set oLib = ThisApplication.AssetLibraries("Autodesk Appearance Library")
    Set oAsset = oLib.AppearanceAssets("Gold")
    If ThisApplication.ActiveDocumentType = kPartDocumentObject Then
        Dim oPart As PartDocument: Set oPart = ThisApplication.ActiveDocument
        oPart.ActiveAppearance = oAsset
    ElseIf ThisApplication.ActiveDocumentType = kAssemblyDocumentObject Then
        Dim oAsm As AssemblyDocument: Set oAsm = ThisApplication.ActiveDocument
        Set oAsset = oAsset.CopyTo(oAsm)
        Dim oOcc As ComponentOccurrence
        Set oOcc = oAsm.ComponentDefinition.Occurrences(1)
        oOcc.Appearance = oAsset
    End If
End Sub
Ruth Steed
Inventor Development Team
