Inventor Programming - iLogic, Macros, AddIns & Apprentice
Inventor iLogic, Macros, AddIns & Apprentice Forum. Share your knowledge, ask questions, and explore popular Inventor topics related to programming, creating add-ins, macros, working with the API or creating iLogic tools.
Change parameters in a part occurrence which is inside an assembly
6 REPLIES 6
oransen
667 Views, 6 Replies
I have an assembly which contains a CComPtr<ComponentOccurrence> pThisCompOcc , and I'd like to do two things.
  1. Get the name of the "base" object, not the display name of the occurence
  2. Change the model and user parameter values of the occurrence
I suspect that I need to find the function or method which gives me a CComPtr<PartComponentDefinition> pPartCompDef which the occurrence points to for the Q1, but what about Q2?
Presumably the parameters are associated with the ComponentOccurrence and the "real" name is associated with the PartComponentDefinition?
Anyway, does anyone know how I do 1 and 2 ?
6 REPLIES 6
oransen
in reply to: oransen
Ok, rummaging around I've found out how to find the name of the "base part", by using a ReferencedFileDescriptor:
CComPtr<ReferencedFileDescriptor> pRefFileDesc = nullptr ;
pThisCompOcc->get_ReferencedFileDescriptor (&pRefFileDesc) ;
CComBSTR bstrDisplayName;
pRefFileDesc->get_DisplayName (&bstrDisplayName) ;
wprintf (L"Component occurence %02d <%s>\n",lOccCount,bstrDisplayName);
::SysFreeString (bstrDisplayName) ;
 But I'm still wondering how to change the parameters of that "inserted instance" of the part.
Vladimir.Ananyev
The key object is the occurrence definition.  Having definition you may get references to the "base" document, properties, parameters, etc.:
ComponentOccurrence.Definition.Document property returns the reference to the Document object (PartDocument, AssemblyDocument).
ComponentOccurrence.Definition.Parameters property returns the reference to the parameters collection.
Vladimir Ananyev
Developer Technical Services
Autodesk Developer Network
oransen
in reply to: Vladimir.Ananyev
Thanks for that, I'll have to see if I can translate it properly into C++!
oransen
I've not been able to translate the VB example into C++. I cannot find the get_Parameters function in the ComponentDefinition pointer:
CComPtr<ComponentOccurrence> pCompOcc = ... ;
CComPtr<ComponentDefinition> pCompRef = nullptr ;
pCompOcc->get_Definition (&pCompRef) ;
pCompRef->  // which function do I call here to get the parameters?
So I'm still not able to get the parameters of the Occurrence...
adam.nagy
Have just written a blog post about this: http://adndevblog.typepad.com/manufacturing/2013/09/cast-between-com-types-in-c.html
Cheers,
Adam Nagy
Autodesk Platform Services
oransen
in reply to: adam.nagy
Thanks!
